I purchased a 2003 Electra Glide from a co-worker. The bike is in good shape, , but the inner fairing could be replaced. The windshield bolts are stripped. Could anyone recommend a solid inner fairing replacement for a 2003 FLTH and/or a solution to the stripped windshield bolts. Thanks
Your "solid" replacement would be a new or takeoff.
You can pickup a takeoff on Ebay for around $100.
A new from dealer is around $175.
This would also be best time to color-match.
If you color-match, don't forget your switch cap. New from dealer, these are around $20 bucks.
Your local dealer sells bolt inserts to replace the stripped out inserts, about $1.50 each.
