speedometer calibration
Old Aug 17, 2013 | 02:50 PM
mile high king's Avatar
mile high king
If you have a 2008 or later throttle-by-wire WITH cruise control, the yellow box will rendor the cruise inoperable unfortunately....so NO GO solution for me. I have a yellow box on a Suzuki and it works great BTW.
Originally Posted by CHEYENNE
All speedometers are off from the factory.
There is also a thing called the Yellow Box that fixes the speedo.
http://www.blackrobotics.com/ I've used it before with great results on my sportbikes and others that I know.
Old Dec 29, 2014 | 04:15 PM
shotgun1133's Avatar
shotgun1133
Speedo Healer by Healtech makes a recalibrator for big twins now. $109.00. I have used them on other makes of bikes and they are dead nuts on. They are plug and play, just use there online calculator to calibrate. Takes about 5 mins. or less. www.healtech-electronics.com
Old Dec 29, 2014 | 05:12 PM
vzts4q's Avatar
vzts4q
This is also true with the Dakota Digital calibrator. It also makes you 6th gear light inoperative.
Old Dec 30, 2014 | 05:24 PM
Punjabi Rider's Avatar
Punjabi Rider
Our 07 and 08 UCs are 4 to 5 % off in speed and also in distance but both clocks run little faster need adjusting every few months no biggy. I have told the tech and his answer it's normal and can't be adjusted but can be replaced if it's out HD specifications but seems like all the things you think are not working properly are within HD standards.
Old Dec 30, 2014 | 06:59 PM
SafetyMan's Avatar
SafetyMan
Holy Old Thread Batman!!
4% is usually what they're off.
They CAN be calibrated with a proper tuner. I know for sure TTS and PV2 can... and I assume FP3 can all do it, but the SE products can not.
Old Jan 20, 2017 | 03:50 AM
bodgie1307's Avatar
bodgie1307
Will the speedo healer render my digital gear display and 6th gear light inoperative on my 2014 breakout..the Dakota sim-1A has rendered both my display and light inop
Old Jan 20, 2017 | 04:28 AM
Keithhu's Avatar
Keithhu
Ancient thread resurrected twice.
Have you called Dakota Digital? I could be going out on a limb here, but I'm guessing they know their products better than people on the forum.
And generally on this thread - factory speedo calibrations will always show you are going slightly faster than you really are.
Why? Can you imagine the law suits they'd be flooded with if it was the other way around? People do all kinds of whacky things to their bikes - different profile tires, different tire inflation, etc, so they are giving themselves some wiggle room.
Old Jan 20, 2017 | 04:37 AM
bodgie1307's Avatar
bodgie1307
I changed my cogs hence the need for recab...got onto Dakota and they said try putting more error into calibration currently it's at 4% & indicators still inop other than adding more error they didn't offer any other solution..it does say on their site that gear indicators maybe inop.
Spouse I could try adding more error say 5 to 10% but the module is under seat and near impossible to cab whilst riding..the dealer used a dyno to cab during the cog change but is reluctant to recab with increased error in the hope the indicators start working..the only other way is to lengthen the wires so I can bring module out from under seat and use gps whilst riding to recab to 5%
rgrecco
Aug 2, 2017 12:20 AM
FuzzyWuzHe
23
May 1, 2016 08:18 AM
AustinRider
Aug 11, 2008 02:02 PM
PoCoBob
Jun 17, 2008 08:49 AM
Moby
May 17, 2008 11:38 AM
