good map # for a break-in download
Old Dec 26, 2008 | 07:05 PM
mikestreet's Avatar
mikestreet
Question good map # for a break-in download
Could any of you smart(er than me) guys give me a good map # for a download to use during break-in for the following build??
Woods tw6-6 cam, SEAC, SERT, Supertrapp 2:1 megs, 103 bore with wiseco 10.5:1 compression pistons, upgraded valve springs, adjustable push rods, 30 tooth Andrews transmission pulley and stage 1 port of stock heads by Henderson Performance.
Any suggestions or comments on the build? Am starting it next week and would greatly appreciate knowledgeable feedback!
__________________
Old Jan 20, 2009 | 08:22 PM
mikestreet's Avatar
mikestreet
Default Break-in question after build to 103"
Well...my build is complete, and the bike seems to be running well enough to break in without a download. Has some lean spots, but am keeping throttle back and under 3200 rpm without lugging. According to Big Boyz calculator, static compression is at 10.6:1, dynamic and 9.77:1 dynamic. Planning to change oil at 200 miles and dyno at 500 +. Any thoughts or recommendations??
Build on 07 SG is as follows: Woods tw6-6 cam, SEAC, SERT, Supertrapp 2:1 megs, 103 bore with wiseco 10.5:1 compression pistons, upgraded valve springs, adjustable push rods, 30 tooth Andrews transmission pulley, compression releases and stage 1 port of stock heads by Henderson Performance.
terryjck
Exhaust System Topics
Aug 21, 2009 09:08 PM
mikestreet
Dec 9, 2008 07:42 PM
masterblaster
Mar 15, 2008 09:15 PM
classicglide
Jul 29, 2007 02:43 PM
kurtzimmi
Dec 27, 2006 10:51 PM
