TourPak Drilling Help
Old Mar 18, 2010 | 07:43 AM
Badfinger's Avatar
Badfinger
Originally Posted by RandyS
What do people use to seal out the water???that is do you put silicone in between the rack and the tourpack...I do not have mine yet...oick it up next weekend so not sure if they come with something or if it is a rubber washer that does the trick????thanks!
The plastic washers that come with the rack should keep any water out at least down to 30 feet I also recommend the Brad bit it's perfect for this type drilling.
Old Mar 18, 2010 | 02:46 PM
jberg's Avatar
jberg
Comes with rubber washers and a template. Dont use the template. Blue painter's tape and measure many times before drilling. I placed mine close enough to the backrest so that my fingers just fit between. That way you can add the spoiler later if you wish.
I put a small amount of silicone on the threads of the bolts to keep water from tracking down. Works fine.
Tip: I put 1/2" felt adhesive disks on the bolt heads so they don't scratch my helmet when I store it in the TP.
Old Mar 18, 2010 | 02:52 PM
ashmarc's Avatar
ashmarc
Originally Posted by Glenn W
Use the right tool for the job-a Unibit (step drill) is the only way to go for holes up to around 1-1/4".
What he said, but one of these, take care of it, you'll use it for years....
speedracerx0509
Audio Systems
Sep 23, 2013 06:20 PM
03_Nightrain
Powdercoat & Paint
Apr 21, 2013 09:17 AM
03_Nightrain
Powdercoat & Paint
Apr 7, 2013 12:30 PM
carltex
Apr 21, 2012 08:38 PM
