Chrome rotors
Old Dec 31, 2008 | 12:50 PM
dgriffith's Avatar
dgriffith
Go for it. While it's in the shop get a set of Lyndall brake pads. No more dust!!!! I will take but a few miles to seat them in and you'll be glad you did. Yes they are a little pricey,but NO DUST
Old Dec 31, 2008 | 12:58 PM
moondog99's Avatar
moondog99
No it is simple though. First remove the rotors. Using a palm sander start with 400 grit sand paper and sand enough to completely smooth the rotors, then move to 600 grit then 1200 grit and finally 2000 grit. The get a drill and attach a four inch sewn polishing wheel (Home Depot)to the drill using a long bolt, nut and washers making the polishing wheel snug on the bolt. Then using a quality polishing agent such as Glitz buff the rotors to a chrome like shine. It sounds time consuming but it only took about 2 hours to do both rotors. Then about every six months clean the wheels with Brasso or similer product and they will look great for years. And while I had the front wheel off I removed the front fender and also polished my lower forks the same as above. Both turned out great. Hope this helps.
Old Dec 31, 2008 | 12:59 PM
FUQUA's Avatar
FUQUA
Just got a set of Chrome rotors they look great in the box haven't hit the road with them yet i'll let ya know when i do.
Old Dec 31, 2008 | 03:22 PM
fixxr's Avatar
fixxr
If you shop around you can get polished rotors brand new on E-bay for$50.each
Old Dec 31, 2008 | 03:39 PM
LiveLifeLarge's Avatar
LiveLifeLarge
OZONEMAN,
That front wheel of your looks great. Can't tell by the pic but is that a chromed stock wheel?
CB2060
Wheels/Tires
Nov 25, 2017 05:38 AM
laabdog
Apr 16, 2017 05:31 AM
cruzmisl
Jun 10, 2012 05:05 PM
Cheeze
Nov 21, 2010 05:29 PM
Dustmaker
Dec 23, 2008 10:23 PM
