As I said in another post, I need to go with electric gloves and need opinions between Gerbing & HD. Seems gloves are the only thing I'll need. Thought I'd hook 'em up to the tender's SAE2, a direct line to the battery.
I assume:
- the wire is a pigtail. Wire to each glove 7 a main to the tender's SAE2. Hopefully the wires are long enough to accomodate long arms and down to the SAE2.
- an adjustable termostat is standard
- I'll have to get a job to pay for this
Only 'problem' I see is with the winter suit I wear. It'd be good if there was a hole in the back somewhere to run the main wire through (to the tender's SAE2). There is not. Cross that bridge when I get there.
THERE IS NO DIFFERENCE. Gerbings makes the gloves for HD. HOWEVER, HD's gloves have a one-year warranty on the electrical components, while Gerbings (the very same glove) have a LFETIME warranty for the same electrical components. They cost the same.
I bought the Gerbings because of the warranty issue.
Sounds good. Classic Men's or G3? To me it's difficult & a gamble to order clothes of any kind online. Might'z well keep the box for return is my history.
I think it'd be wise to order by phone. I've seen posts where they really help when ordering. Might clear up things like wiring etc...
Go with Gerbings. If you decide at some later time to add a jacket, they will work with it too. I have had Gerbings gear, pants and jacket liner for 14 years now and the only time I had a problem was one year ago. Gerbing fixed it and got it back to me in two weeks........no charge!
I have the G3 gloves and they come with a Y cord to power them down your sleeves. The jacketliner they have has small zippers on the top of the wrist where the power coard for the gloves comes out. The jacket comes with a power cord to hook up to the battery terminals. And as stated, the controller is seperate. Get the duel one, because the first time you ride with a heated jacket, you'll buy one! Ask someone who has one. As for the size/fit. I went and tried on some at dealers till I found the right size. I found a Gerbings dealer 60 miles away and rode up there to try on the gloves and jacket. Then I ordered the size I needed. The dealer stuff was 3 years onld and demos.
Gerbring will honor any HD heated gear made by them with the same lifetime warranty. Call and ask them if you wish. Gerbing cost less then HD I bet. I have the heated vest and love it.
