View Poll Results: Heel to Toe Shifters--what is your preference?
Heel and Toe?
332
59.82%
Toe Only
223
40.18%
Voters: 555. You may not vote on this poll
Heel to Toe Shifters?
Old Jan 7, 2009 | 06:49 AM
  #141
ctmedic's Avatar
ctmedic
Default Heel Toe Shifter
Love the heel toe shifter. Never had a problem with it. Only size 8.5 shoes here
Old Jan 7, 2009 | 09:43 AM
  #142
Chas63's Avatar
Chas63
Originally Posted by Hawgnut
When I first got my 08 FLH I thought I was going to like the heel/toe, but since then my left knee has been killing me........ I Know it is coming from lifting my knee up everytime to shift because if I don't ride it for a couple days my knee quits hurting. I've seen lowering kits, I might go that way. But for now I'm Thinking Toe only
Do you lift your entire foot off the floorboard when you use the heel shifter? If so, that may be the cause of your knee problem.
I simply raise my heel a couple of inches and then give a sudden push/stomp down with my heel to shift. I usually stomp it pretty hard. Never had a problem yet with my knee or the shifter.
Old Jan 7, 2009 | 12:18 PM
  #143
gunner11's Avatar
gunner11
I just loft my heel and shift, don't even stomp most of the time.
Old Jan 7, 2009 | 12:33 PM
  #144
garyhendley's Avatar
garyhendley
i also use both -ride safe
Old Jan 7, 2009 | 06:35 PM
  #145
ENTERPRISE's Avatar
ENTERPRISE
Both,nothing better than jamming up the gears with just the tap of your heel.
Old Jan 7, 2009 | 08:53 PM
  #146
comaman2's Avatar
comaman2
i like the heal toe,it hasnt given be a reason to take it off
Old Jan 8, 2009 | 09:36 AM
  #147
racklefratz's Avatar
racklefratz
Originally Posted by notlost_nc
I'm lazy, I don't want to lift anything. I use both.
Same here. Why screw up the toe of a good boot when all you have to do is rest your heel lightly on the rear one and let it go down from gravity?
I only have a toe shifter in my Goldwing, and it works fine due to the short travel to shift. My UCs a different animal; the shifter travels a LOT farther for each shift making for quite different ergonomics. I very much like having the option to use my heel when I feel like it, which is frequently.
Old Jan 8, 2009 | 11:10 AM
  #148
racklefratz
Originally Posted by StreetGlider57
I use both, only because the heal shifter is there. But I'm considering removing it because I'd like to the extra space on the floorboard to move my foot around.
Get HD pn 33876-07 and you can keep the "heal" shifter AND have the extra space on the floorboard.
Old Jan 8, 2009 | 11:13 AM
  #149
racklefratz
Originally Posted by Chas63
To add to my previous comments, a heel shifter is a much more positive way of shifting gears. It's much easier to exert a force downward with my heel than it is to pull upward with my toe.
I've noticed that too. I wonder how much all the shifter linkage failures are related to stomping down on that rear shifter.
Old Jan 8, 2009 | 11:35 AM
  #150
jsimo7's Avatar
jsimo7
both for me
