Adjustable air ride compressor for street glide
Old Jan 8, 2009 | 06:18 PM
3itodd's Avatar
3itodd
Default Adjustable air ride compressor for street glide
Hey hows it going guys, My buddy is wanting to get a air ride system for the rear of his his street glide with a on board compressor>I am most likely going to help in this job and I was wondering has anyone done this before and where did you locate the compressor and what systems are good and bad I dont want to see him buying some junk set up! Thanxs alot for you'r info!
Old Jan 8, 2009 | 06:45 PM
kruzin's Avatar
kruzin
I used the Arnott system and really like it. The compressor comes with a mounting bracket that slips into some tabs under the battery. Neat install. I wired the up down switch to my PPT switch, with relays, as I do not use it for anything else. I do believe the kit will come with handlebar switches but check with them to be sure. The full kit is around $700.00 if I remember correctly but go to the website and check them out.
Old Jan 8, 2009 | 07:56 PM
assassin307's Avatar
assassin307
I installed the Arnott Aldan system on my 07 Ultra. I love the setup. The compressor mounts under the battery box and the only issue I had is that a coal / smog canister was mounted where the compressor needed to go (I have a California emmisions bike). Once the canister was removed, it was a pretty simple install. I also got the air gauge, whcih works great. I think your friend will be happy with the system.
The Aldan set was about $1000. I went with the 13" shocks so when the system has no air, the rear of my bike rides some 3 inches lower but wont rub my 18" rear rim.
Old Jan 9, 2009 | 08:37 AM
Heathen's Avatar
Heathen
Got the Arnott on mine,also ordered air gauge,used 12'' shock w 16'' wheel,can run deflated but rides like a rigid.Hope this helps.
Old Jan 9, 2009 | 10:56 AM
assassin307
Yup, ride sucks with all the air out, but it sure looks cool. Whats nice is the ride becomes comfy again when you air it up. The wife definitely appreciates that!
I couldnt go with the 12" because it would have rubbed against the 18" wheel.
Old Jan 10, 2009 | 12:45 PM
3itodd's Avatar
3itodd
what is a ppt switch? thanxs
Old Jan 10, 2009 | 01:36 PM
gilbos440rt's Avatar
gilbos440rt
The switch for the CB equipped bikes, not used on other bikes
Old Jan 10, 2009 | 01:37 PM
gilbos440rt
How much diff does the rebound damping selector on the Aldan's make?
Thanks in advance!
rblahetka
Jul 26, 2017 02:51 PM
RaeRae
Oct 6, 2016 08:01 AM
ejvette
Feb 12, 2014 07:47 PM
Overdoo
Sep 25, 2008 09:00 PM
2006streetglide
Oct 19, 2006 05:30 PM
