torx screws
Old Jan 9, 2009 | 10:23 PM
jackinthebox's Avatar
jackinthebox
Default torx screws
To everyone who has replaced there torx with allen head chrome screws what size did you use
Thanks
Old Jan 9, 2009 | 11:23 PM
skratch's Avatar
skratch
the same size as the screw that i replaced.....
Old Jan 10, 2009 | 08:55 AM
1flhtk4me's Avatar
1flhtk4me
There are specific kits availible that have the correct lengths.
Old Jan 10, 2009 | 10:15 AM
Ultra61's Avatar
Ultra61
This is beyond my normal thinking...why do this?
Torx are stronger and look nicer right.
Spend no money...
The indy/tech is less confused...and then inturn less labor.
Old Jan 10, 2009 | 10:20 AM
HDRider2002's Avatar
HDRider2002
I decided to put the security Torx on my bike, just to be original
Old Jan 10, 2009 | 10:31 AM
beary's Avatar
beary
Spend no money...
I'm not trying to argue, I'm just giving a different perspective and I look forward to replies:
1. Looks are subjective.
2. Less tools required to work on bike and to take on trips.
3. Good quality (hardened steel) #27 bits are very hard to find. I can find decent allen tools at the next corner.
4. Torx are stronger in design, but for some reason I have stripped more torx heads than allens.
Those are my thoughts being the switch.
Beary
Old Jan 10, 2009 | 11:06 AM
captjon37's Avatar
captjon37
I dump every torx i remove. so far lowes has worked for me in finding the stainless allens. the chrome ones will crack and rust over time. Take the old ones with you and match them up.
Old Jan 10, 2009 | 11:33 AM
Dionicio's Avatar
Dionicio
Beary
Snap-on.com has a good set of torx bits. They will not break or screw up torx fasterners when used properly. the t27 and all other sizes are available. No I do not work for Snap-on, I just perfer using quality tools that won't let me down in the middle of a job.
Old Jan 10, 2009 | 12:12 PM
jrhd1's Avatar
jrhd1
Whether you use allen or torx is a personal preference. Just make sure you go with polished stainless. I used chrome the first time around on my ride and ended up going to stainless because they will rust on the inside of the head of the screw in time. I have my engine out of my bike right now and will be replacing all the bolts with polished stainless as well.
Take a look at www.depss.com
Old Jan 10, 2009 | 12:55 PM
BigGdawg's Avatar
BigGdawg
Thanks
Ace Hardware has been able to give me any screw I wanted to replace, usu available in Stainless Steel as well as plated.
