Should I?
Old Jan 18, 2009 | 09:22 AM
BadPiggy's Avatar
BadPiggy
Default Should I?
Installing in my brother's bike:
Wiseco 9:1 forged pistons, 95"
Andrews TW37B cams
Baisley LSR2 spring
Putting new inner/outter cam bearings in.
Bike has approximately 15,000 miles
He bought it last Fall
'99 EG Standard
While I'm in there, should I go ahead and change the chain tensioners?
Old Jan 18, 2009 | 09:27 AM
Abnmarine's Avatar
Abnmarine
Any chance on getting the heads worked? That would benefit the build the most. Definitely replace the cam tensioners.
Old Jan 18, 2009 | 10:00 AM
strtrod's Avatar
strtrod
I noticed you have alot done to yours. I know this is a little surprise for him. A little head work & wright cam, then you can say welcome to my world. It doesnt have to be ***** to the wall. 10:1 would let stay close. with u
Old Jan 18, 2009 | 10:07 AM
BadPiggy's Avatar
BadPiggy
It would have to be a very little head work, maybe a "cleanup" job.
My brother's company is struggling and he doesn't have the money for this.
I'm footing the bill for the motor work and I can't sink a lot into his bike.
If I could get the heads cleaned up for around $300...I'd do it.
I can't afford to put $1000 into his heads when I'm in the beginning stages of a HQ 120" build.
Old Jan 19, 2009 | 09:17 AM
Heathen's Avatar
Heathen
Id skip the heads for now and try to get a gear drive,Heads can be done when times are better.
Old Jan 19, 2009 | 09:30 AM
gmc's Avatar
gmc
Nice brother. I don't know but I though the old ones were only good for 30-40,000 miles and the new ones were much better. Keep up the good work.
Old Jan 19, 2009 | 09:56 AM
Harleypingman's Avatar
Harleypingman
IIRC, the cam chain tensioners are $31 each, so $62 for both list, and a definite R&R since you will have the cam plate out.
I purchased the LMR oil pressure relief spring but didn't install it when my cam chain tensioners were replaced and HQ-0034 cams installed because I had read of very high oil pressures (basically, pegging the gauge) on start-up. My oil pressure has been fine since the installation roughly 20K miles ago.
Very nice things you are doing for your brother; hope he appreciates it.
Last edited by Harleypingman; Jan 19, 2009 at 10:26 AM. Reason: Corrected price of tensioners
Old Jan 19, 2009 | 01:08 PM
BadPiggy's Avatar
BadPiggy
Where are you getting new tensioners for $31 each?
I just left my local HD dealer, got the price while I was there...$67 each.
I'm also putting the LMR-2 spring in...I think it was $16 to my mailbox.
Old Jan 19, 2009 | 04:35 PM
notlost_nc's Avatar
notlost_nc
did mine here : http://www.bigboyzcycles.com/showthread.php?p=17
Definitely replace the tensioners, or go with the Andrews Roller Cam Conversion as long as your using their 37.
I'm forwarding this to my brother so he can save up to build my motor
pegskraper
Engine Mechanical Topics
Oct 29, 2016 10:22 PM
Dan33klein
Feb 19, 2013 02:54 PM
mrdakotaman
Oct 14, 2009 05:29 PM
kansasroadking
Exhaust System Topics
13
Aug 15, 2008 03:29 AM
tiiiim2
11
Apr 15, 2007 12:41 AM
