Removing Heel Shifter - HELP!
Old Feb 14, 2009 | 03:59 PM
tenacean's Avatar
tenacean
Default Removing Heel Shifter - HELP!
Ok, before I go ballistic...
I'm trying to remove the heel shifter lever on my '05 RK Custom...does the screw/bolt that holds it on screw in the correct way - clockwise??? It's not some sort of reverse threaded screw right?
This should have been a simple removal and I've stripped out the screw...a bold remover can't get a grip...a vise grip wrench doesn't work...I've tried extreme heat...nothing...
Thoughts out there??
Thanks!
Old Feb 14, 2009 | 04:04 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Righty tighty, lefty loosey......No left hand threads. The bolt has to come out b4 you can remove the shift lever...if you pry on the lever without removing the bolt you will f the splines on the shaft. You really dont want to do that.
You may have to get an air operated cut off wheel or small grinder and cut the shift lever towards the bolt to seperate into two pieces. I would first try to drill a hole in the bolt and use a easy out. Not much room to use a drill there though.
Old Feb 14, 2009 | 04:09 PM
jimmything's Avatar
jimmything
Sounds like you might have to drill that puppy out.
Old Feb 14, 2009 | 04:13 PM
sooie's Avatar
sooie
just leave it on !!
Old Feb 14, 2009 | 04:20 PM
05Fatty's Avatar
05Fatty
Drill it out, you can always get a new lever if you need it. I'd just use a bit that is slightly smaller than the diameter of the bolt. Good luck.
Old Feb 14, 2009 | 04:29 PM
oinker02's Avatar
oinker02
Originally Posted by sooie
just leave it on !!
OUCH!
The shaft is splined to prevent the shift levers from spinning. There is also circular grooves cut in the splined shifter shaft that the retaining bolt fits in to prevent the shift lever from sliding off if the bolt is loose....so there really isn't any way to slide shifter off shaft unless bolt is removed.
Yeah, these things do manage to fall off all by themself but that's another story.
You need to get the bolt out or cut the lever off.
You can either cut the bolthead off or the nut, then tap the bolt out.
You can also cut the actual lever clamping collar off. The clamping collar is the part the bolt slides thru that surrounds the shifter shaft.
It's possible that you might be able to grip the allen head bolthead with vise grips and then loosen the lock nut-then slide bolt up and out.
I'm with you in removing the heel shifter! I hate them!
Old Feb 14, 2009 | 04:53 PM
hogbag07's Avatar
hogbag07
I would try and knock it out with a punch from under the gear lever if the thread is striped.
Old Feb 14, 2009 | 05:01 PM
tenacean's Avatar
tenacean
The head is stripped...not the threads...just can't get a grip...
I like my heel shifter...I'm removing it to replace a damaged primary cover.
Old Feb 14, 2009 | 05:04 PM
oinker02's Avatar
oinker02
Can't imagine why you like it, but I accept that you do and you ain't gotta explain.
Go ahead and get mean with it. I'll ship you my old one if you destroy yours getting it off...It ain't got 2 miles on it.
Old Feb 14, 2009 | 05:15 PM
n8dc's Avatar
n8dc
I hate to say it but if youve f^&*ed up the bolt head on the shifter id thinking about letting someone else do the primary cover
Dave
