Got the ones from Harley they are great and cheap. The two sided tape has not failed me. However if you go with the matching trim rings for the speedo and gages (and you will.) Use a small amount of silicone on those or they will come off. Mine have not moved since I put a drop or two of silicone on them. Everything together looks great.
I was at Lowe's the other day, looking at the expanded metal selection in the Hardware Dept. I found some that looks like stainless, but is aluminum and am going to get a piece and cut it to fit inside the black trim rings on the rear and over the front ones. Figured on using double sided tape for the front. It has small holes(one every 1/4" or so)also available in other patterns.
I bought the HD speaker trim. After, I dremeled the bar that goes across the center of the trim, sanded the areas, and painted the exposed areas with silver enamel. Now, the trim matches the bezels on my gauges and no one can even find the sides where the silver paint is located.
