09 High Idle Question
Old Feb 22, 2009 | 07:43 PM
Conehead's Avatar
Conehead
Default 09 High Idle Question
My RPM's are around 1500 or so until the bike gets warm. It has been taken to dealer and they advised it is fine. I do have a PC V installed but it was doing this before the install. It will settle down after driving a couple of miles. Anybody else having a similar issue? Is it normal?
Old Feb 22, 2009 | 07:50 PM
hep0950's Avatar
hep0950
08s had a simular thing going. There if the idle did not come doen you were to back the trottle down as far as possible and then shut off the engine. Then you turn the ignition on at the switch and button and turn it off at the same place three times without starting the engine to set the computer. It's on switch then button, then off button and switch three times. It should start up then and idle lower.
Old Feb 22, 2009 | 07:53 PM
Donnylee's Avatar
Donnylee
Cold fast Idle is normal
Old Feb 22, 2009 | 08:29 PM
1potter1's Avatar
1potter1
I have the same bike same issue, Its cold idle. I believe its designed to keep the EPA happy..
Old Feb 22, 2009 | 09:39 PM
Dallastx's Avatar
Dallastx
Yep. The fast idle heats the engine quicker so it will burn fuel efficiantly.
D
Old Feb 22, 2009 | 09:44 PM
Conehead's Avatar
Conehead
Thanks!!
SA315B
Apr 9, 2017 10:38 PM
Jackal
Mar 8, 2012 09:21 AM
OD_Cleaver
Jul 7, 2009 09:36 AM
jhopwood
Screamin Eagle CVO Models
Apr 6, 2009 03:27 PM
johnica
Jun 18, 2008 06:34 PM
