Brake Pad life Expectancy
Old Mar 10, 2009 | 01:08 PM
  #31
poppa cooter's Avatar
poppa cooter
Talking
Originally Posted by Leftcoaster
My '95 EGC still has the original pads front and rear and with 45K+ miles show about 50% (I have a new set for comparison). My '06 Streetglide w/25K shows about the same. I ride both bikes hard and fast and consider my brake pad life to be about normal. My riding buds do about the same. The EGC has had 9 rear tires and 4 fronts - the Streeter is on it's 3rd rear and 2nd front.
now that's some pads.
Old Mar 10, 2009 | 01:34 PM
  #32
Watchfuliz's Avatar
Watchfuliz
I have almost 18k on my pads and they are only 50% worn. I have an 08 also. The rear brake squeal is a problem they are having with 08 and 09 models. There is a service bulletin on it. They will put a paste on the rear pad that will stop the squeal under warranty if you make a complaint about it. If you need rear brake pads though you have to pay for the kit then. They tried to tell me I needed new pads.........LOL. I told them no just put the paste on. They did and no squeal now. Service bulletin # M1228.
http://home.comcast.net/~bertkk/HDPi...ad_Service.jpg
Old Mar 10, 2009 | 09:45 PM
  #33
garyhendley's Avatar
garyhendley
i have over 21,000 on the original pads i just bought some lyndall pads for a soon
brake job -ride safe
Old Jun 3, 2012 | 07:25 PM
  #34
PCJack's Avatar
PCJack
6th Gear
Much like Chula, I'm a highway rider....about 500 miles a week. I will be crossing 60,000 on m08 Ultra within the next 2 weeks, and this is the second set on my front wheel, just did them today. I seem to get much more miles per set of pads on my Ultra than my wife does on her Heritage Softail. May also have to do with the fact that mine is dual rotor on front and her's is a single and she is mainly an in town rider. But the bottom line is I put at least 50x the miles per month she does. She only drives 3 miles to work, I'm 48 miles each way. Good luck!
Old Jun 3, 2012 | 07:34 PM
  #35
bigdumbnoitall00's Avatar
bigdumbnoitall00
07 35,000 and still on original pads front and rear.90% 2 up.
Old Jun 3, 2012 | 07:35 PM
  #36
hd_rolling's Avatar
hd_rolling
28,000 on my stock pads so far and haven't needed to change front or rear. Lyndal Z's hanging on the wall waiting for my next tire change.
Old Jun 4, 2012 | 09:58 AM
  #37
kjelders's Avatar
kjelders
I just replaced the stock pads this past weekend on my 07 UC. I have 39k on the bike. The front pads had about 45% left on them but the back pads were almost metal to metal. I bought Lyndall pads at a local indy. They only had one set of Gold plus so I put them on the rear brakes and went with Z plus on the front.
Replacing the front pads was fairly easy and had them done within a hour. The rear pads was a different story. I tried for over an hour trying to do the replacement without removing the wheel per manual. There was no way I could get the new pads in. So, I told myself I needed to learn how to remove the rear wheel and put it back on by myself. With lot's of "yoga" maneuvers, facial expressions, grunting and numerous breaks I succeeded in removing the rear wheel, replacing the brake pads and re-assembled. Yoga sucks!
Chuck1
Jun 23, 2017 12:36 AM
Smurfshxt
Jun 15, 2015 10:58 PM
rcmonroig
Dec 14, 2014 04:54 AM
fzggm4
Mar 24, 2011 04:42 AM
PPBART
Jun 4, 2010 11:50 AM
