Need to settle argument
Old Mar 10, 2009 | 07:22 PM
cannedham1's Avatar
cannedham1
Default Need to settle argument
Hey Guys,
I need help settling an argument with a friend. I am going to lower my 07 rk custom 1 3/4 using bitchin baggers shocks. He says I will have to lower the front. I will if the ride is affected but I thought I read on here that it isnt a must. I tried the search but no luck. Does anyone have any thoughts on lowering the front and the shocks.Thanks.
Old Mar 10, 2009 | 07:27 PM
CrashX's Avatar
CrashX
You don't need to lower the front unless you want to. The SG has the same front end as the other touring models, with the shorter shocks in the back, and it seems to work.
Old Mar 10, 2009 | 07:30 PM
adam_kurtz's Avatar
adam_kurtz
your custom is lowered 1" from other kings from the factory.12"shocks instead of 13"
Old Mar 10, 2009 | 07:33 PM
catracho's Avatar
catracho
No mod in front needed, will work fine.
Old Mar 10, 2009 | 07:49 PM
garyhendley's Avatar
garyhendley
i agree nothing in the front is needed unless you want to lower it -ride safe
Old Mar 10, 2009 | 07:50 PM
Chula's Avatar
Chula
sHOULD WORK FINE
Old Mar 10, 2009 | 07:52 PM
Yatez004's Avatar
Yatez004
Youll be all set. Only preference if you lower the front...
Old Mar 10, 2009 | 07:56 PM
Screamin Steve's Avatar
Screamin Steve
You can always lower the back without lowering the front, however I was told by Harley that you can't lower the front without lowering the back! Seems to make sense.
Old Mar 10, 2009 | 07:57 PM
EasternSP's Avatar
EasternSP
Originally Posted by cannedham1
Hey Guys,
Lowering it that much may cause tire rub under your fender. Depending on how much you weigh or if you ride two up, be aware of this so you don't tear out wires or rip your tire up.
scooter_984
Mar 1, 2010 01:00 PM
cannedham1
Mar 9, 2009 07:09 PM
profive0
Oct 21, 2007 07:00 AM
vegashd
May 9, 2006 04:16 PM
Matt8643
Oct 16, 2005 03:29 AM
