Panacea Light System
Old Apr 27, 2006 | 05:03 PM
StL Mike's Avatar
StL Mike
Default RE: Panacea Light System
Guys,
I installed the Kuryakyn Panacea LED system, smoked lenses, front and rear on my 05 Road Glide. I also have the laydown rear lense, and HD's spoiler LEDs on my chopped Tour Pak. I didn't install the equalizer on the front turn signals, but I did install the one on the rear turn signals. I can't help with the security light issue, but I can say that my turn signals do flash after the bike does it's self test when I turn on power. Kuryakyn tech support told me that this is normal. Give them a call, they are great.
Mike
Old Apr 28, 2006 | 11:47 AM
Bruce00's Avatar
Bruce00
ORIGINAL: HD Renegade
Bruce,
I am no positive, but I thought that, that part came with the Laydown Tail Light?? If not and you ordered it extra, where does it plug in, or do you remove something and replace it with this item??
Bob
ORIGINAL: Bruce00
I did the same thing with the front turn/running LED, rear ED stoplight and rear turn/running lights. Also very happy with the results
You need the TSSM Alarm Compatible Load Equ, part # 14857. I paid $25.49 from M&M Cycle, ordered eveything and had the parts in 5 working days.
The rear LED taillight came with a load equ, and the front LED's came with a load equ, but you need to buy the one I listed to get your security light to stay out. It was my understanding that the alarm would function correctly, but the light would stay on without the alarm load equ
Old Apr 28, 2006 | 12:57 PM
HD Renegade's Avatar
HD Renegade
Bruce,
Thank you for the clairification on it.
Bob
ORIGINAL: Bruce00
Bruce,
Bob
ORIGINAL: Bruce00
Old Apr 28, 2006 | 03:37 PM
Bruce00's Avatar
Bruce00
Glad I could help Bob
Old May 4, 2006 | 08:09 PM
HD Renegade
Bruce,
Just to let you and everyone else know, what you said took care of the problem. The TSSM Alarm Compatible Load Equ, part # 14857 came a yesterday, and it took care of the problem.
Bob
ORIGINAL: Bruce00
Old May 4, 2006 | 08:50 PM
Bruce00's Avatar
Bruce00
Hey........... I was right for the first time in my life
Bob
I have noticed that the security light comes on after I start the bike for about 15 secounds, then goes out. Alarm works like it should, so I guess it's no biggie.
Happy motorings
Old May 4, 2006 | 09:19 PM
HD Renegade
Bruce,
It was not like the light being on after I used a turn signal hurt anything, it just bugged the heck out of me that it would stay on!!! I can handle the key lighting up for 5 or 10 seconds once, as long as it goes off and stays off!!! Hopefully it will get somewhat warmer here soon, and then I will be out more at night with it.
The LED mod was worth it when you think about the safety aspect of it, then there is the cool factor!!
Bob
ORIGINAL: Bruce00
Bob
Happy motorings
Old Sep 1, 2007 | 09:53 PM
willett58's Avatar
willett58
I have the Kuryakyn kit too. When I installed all LED's front and back the alarm light came on when the turn signal was activated. Installed TSSM Alarm Compatible Load Equ, part # 14857 and the binkers would not work. So I finally removed the Load Equ. and front LED's and now everything works fine. I really just need all the rear lights to be LED. Oh, if you buy the kit it does come with a small load equ. Returned the TSSM Alarm Compatible Load Equ, part # 14857 and got my money back. Good luck.
Old Sep 1, 2007 | 10:25 PM
Qball's Avatar
Qball
I had same problem and Kury sent me an additional load equalizer. No help. I purchased the more expensive equalizer from Biketronics.......problem solved!!!
brock161
Feb 22, 2011 11:08 AM
hdpearl70
Electrical/Lighting/Alarm
Jan 7, 2009 08:27 AM
floridabeach
Dec 27, 2008 05:23 AM
sortasuave
Sep 7, 2008 10:11 AM
AsahiToro
Mar 16, 2007 11:45 AM
