Eitms
Old Mar 13, 2009 | 01:28 PM
nemick's Avatar
nemick
Default Eitms
I had noted previously that after installing my new PCV, I was surprised by the strange idle until the bike was warmed up. Upon checking today, I discovered that the EITMS was enabled. I have never enabled this feature, so I presume someone else had.
Having disabled this feature, the idle from cold is rock steady and just what I would have expected.
I had presumed, that even when enabled, that this feature would only activate above a specific temperature. Naturally the Handbook is spectacularly vague on this point. Does anyone know just how this thing works and when?
Thanks
Old Mar 13, 2009 | 01:38 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
its not supposed to engage until the bike is stopped and temps are above 220.
Old Mar 13, 2009 | 01:41 PM
robzuc97's Avatar
robzuc97
Dealer probably will set enable unless specifically told by owner. EITMS only works when the bike reaches a specific high temperature range. It works in three phases: Phase I=ECM detecs temp above 300 degrees and reduces idle speed to reduce combustion events. Phase II=ECM detects temp still going up and richens mixture. More gas has cooling effect. Phase III=ECM detects temp getting higher still and skips injector pulse when stationary at idle. All phases should work seamlessly and not be noticed by rider.
Old Mar 13, 2009 | 01:46 PM
ULTRA Gramps's Avatar
ULTRA Gramps
When you say 300degs. Is that cylinder head temp?
Old Mar 13, 2009 | 02:05 PM
nemick's Avatar
nemick
Thanks very much for the info. I guess my suddenly calm idle must just be co-incidence.
Old Mar 13, 2009 | 02:52 PM
Stang951's Avatar
Stang951
Mine kicks in and is noticeable and is very noticeable when try to take off from a stop. It is almost like it is pinging with the noise that it makes.
Old Mar 13, 2009 | 03:00 PM
nemick's Avatar
nemick
Stang, does your bike idle normally when cold?
Old Mar 13, 2009 | 03:12 PM
Stang951's Avatar
Stang951
It idles a little high (like 1100-1200 rpms) but nothing out of the ordinary. Every fuel injected engine that I have had has done that.
HDSAE60
May 11, 2016 09:12 PM
Arizona Sage
Jan 31, 2014 10:55 PM
Silvertrain1025
Mar 2, 2013 09:31 AM
Brick0044
Nov 19, 2012 01:34 PM
70mach1
Exhaust System Topics
Jul 14, 2006 01:15 PM
