Where's the accessory power?
Old Mar 19, 2009 | 07:20 PM
johnica's Avatar
johnica
Default Where's the accessory power?
On an 06 RK, is there somewhere under the seat to get accessory (ignition on) power for add-ons?
Where is that power fused from? Is that what the P&A circuit is for, I keep hearing about the 'P&A' but am not sure what it is.
Old Mar 19, 2009 | 07:24 PM
bksmoky's Avatar
bksmoky
Check your owners manual. I have an 09 Ultra and it's located right in front of the battery.
Old Mar 19, 2009 | 07:42 PM
tda69's Avatar
tda69
Ditto on my '08 under the seat near the battery.
Old Mar 19, 2009 | 08:04 PM
dan boudreau's Avatar
dan boudreau
There is an empty female plug under your seat which is controlled by the acc. switch on your nacelle. You can get a male plug from the dealer which has a pig tail and you can wire whatever it is you want to this and control with the switch.
Good luck
Old Mar 19, 2009 | 08:15 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
its a small plastic box 9about 3 by 3 with a rubber plugg on top thereS 4 smallmholes (get a tester to figure out wich is what 1 nuetral 1 unswitched 1 acc switch 1 on the running lights get the duetch connector u can skip the pigtail and just crimp the conectors on and plugg them in>
Old Mar 20, 2009 | 01:02 AM
dredy2g's Avatar
dredy2g
Good luck
Is this the same for the FLHPi also
timbo141
Electrical/Lighting/Alarm
Nov 29, 2018 08:21 PM
utazzit
Apr 30, 2017 10:15 AM
capt_caveman
Mar 27, 2011 09:56 PM
bruce86023
Feb 4, 2009 02:51 PM
biz44
Nov 20, 2007 11:27 AM
