Tour Pack Detach rack problem
Old Mar 29, 2009 | 08:51 PM
beary's Avatar
beary
Default Tour Pack Detach rack problem
I'm putting together my tour pack and detach kit. I installed the docking hardware to the bike, then I tried to attach the tour pack mount to it. The right side of the mount was tight but slipped in. The right side was so tight that it broke the plastic grommet on the rear doing point. I'm glad I haven't attached the tour pack to the mount yet, that would made this twice as hard.
Has this happened to anyone else? What was the fix?
Thanks ahead for you help.
Beary
Attached Thumbnails Tour Pack Detach rack problem-rearmtpieces.jpg   Tour Pack Detach rack problem-dsc01473.jpg
Old Mar 29, 2009 | 09:00 PM
Lucky 13's Avatar
Lucky 13
Loosen the bolts on the bike mounts for the first fit. Then remove the tourpac and tighten them down. I actually had to spread the tourpac bracket on mine. The plastic on the mounts is real hard and cracks easily. Good news, most dealers have them in stock, about 8 bucks.
Old Mar 29, 2009 | 09:03 PM
jdreed520's Avatar
jdreed520
Good call Lucky 13 I have not installed mine yet but there have been other post and they talked about having to tweek the rack for the first fit...then tighten everything up. And also most dealers have the plastic pieces so that tells me that it happens allot.
Old Mar 29, 2009 | 09:14 PM
beary's Avatar
beary
I should have tried that, the parts felt so precise that I didn't think there was enough play. I will try that tomorrow. I'm sure that will fix it. Thanks for the help. The rest of it looks pretty easy.
Beary
Old Mar 29, 2009 | 09:21 PM
2003flhtci's Avatar
2003flhtci
When I put mine on, I couldn't get the rack mount to go on the mounting points (I tried it before I installed the tour pak onto the mount). That sucker just wouldn't go.
Then I mounted the tour pak on the rack and it slid right on and has worked right ever since (2+ years). Go figure.
Old Mar 29, 2009 | 10:08 PM
silverbullitt's Avatar
silverbullitt
2003flhtci - Mine looks almost a twin to yours. I did all the detachables this week. Its an 03, same colors. Nice ride.
Old Mar 29, 2009 | 10:17 PM
Donnylee's Avatar
Donnylee
I bought a new back rest (Taller) it did not want to fit the existing docking hardware where my old one did. Was messing with it tonight for an upcoming pre-flight trip. I had to put the new rest it on it side on the ground and give it a mild push to bend it inward (bending it slightly both sides) It went right on after that.
I do not think the backrests themselves are that dead on out of the box after experiencing this. It might help, so I mentioned it.
Old Mar 29, 2009 | 10:26 PM
turbo54's Avatar
turbo54
Beary
I got the tour pack and detach kit for 09 RG last week there is no way in heck mine will work like ya said something is going to brake , the mounts are good but I think the rack is the wroung for the mounts. Im taking the rack back.
Old Mar 29, 2009 | 10:55 PM
bigskyhd's Avatar
bigskyhd
Mine was extremely tight the first go around. So I loosened everything and put the tour pack on while it was not cranked down to spec. Tightened things up with the TP on, detached it, tightened to spec, which wasn't much more, and put the tour pack back on. It's still really tight, but I guess I'd prefer it tight with no movement or vibration than the other option. Good Luck.
Old Mar 30, 2009 | 08:21 AM
beary's Avatar
beary
Yes, I think this is what Lucky13 was suggesting. Don't know why I didn't think of it. I will go buy a new plastic piece and try your method. Just all the fun in doing these projects. I'm glad I'm in not hurry.
Beary
