New shift rod question?
Old Apr 3, 2009 | 05:55 AM
Chuck1's Avatar
Chuck1
Default New shift rod question?
Put a new shift rod and heim joints on. Bike upshifts beautiful (better) but downshifting seems a little different, maybe. Almost seems a little short or slugish. I know when it's cold out, like it is here yet, will do that. Can't be the rod can it? It could be a 1/4 to 1/2 inch shorter than original. If the rod is that close to original, it would only affect the heel and toe height of shifters, right?
Old Apr 3, 2009 | 06:36 AM
Lass7711's Avatar
Lass7711
Chuck, I put heim joints on mine as well, but the length was about the same as stock. Mine shifts fine.
If the shift rod is a lot shorter or longer, it will move the front linkage that the rod connects to away from a vertical position. When that happens, it takes more rotation of the shift pegs to get the same travel at the transmission linkage.
It should take more than 1/2" difference in rod length to feel much difference. I agree that what you're feeling is probably not the rod unless there is play in the rod and joints somewhere.
Old Apr 3, 2009 | 07:02 AM
n8dc's Avatar
n8dc
I measured mine off the old one when i changed it out and it does the same thing. Did you get the ebay one?.. Im thinking the joints are stiff and thats what is causing it . It was fine before . Make sure you take your foot all the way off the shifter when down shifting andd that helps.. I figure it will loosen up and work better over time .
Old Apr 3, 2009 | 07:16 AM
FastHoss's Avatar
FastHoss
The shaft that goes through the case needs to at least be pulled out ,cleaned and regreased,I put a zerk on mine so I could lube it every now and then.
Old Apr 3, 2009 | 07:31 AM
n8dc's Avatar
n8dc
Good idea but mine was fine before i changed it out.. I may play with that today since its raining . I did get a wonderful 60 mile ride in yesterday though .. As I stated earlier i think its the heim joints being new and stiff. Seems like the up shifting isnt quite as noticeable but its still there and when you down shift it really is noticeable.
Old Apr 3, 2009 | 01:05 PM
n8dc's Avatar
n8dc
I went out a fooled around with mine today and its for sure the ***** are too tight in the rod ends.. What i did was spray some pb blaster on them and roll them around a bit then i got it to where i could get the hole in the ball so i could see the inside of the joint and i put some anti seize in the groove. Its better but... The damn chrome is comming off one of the rod ends already? I emailed the place on ebay where I bought it .. Unacceptable ...
Old Apr 3, 2009 | 01:47 PM
n8dc's Avatar
n8dc
So i emailed these guys and they replied with the havent had a chrome peeling complaint and he would sent me out another one (rod end I assume) right away ? .
Guess i cant ask for more was just a matter of minutes from the time i emailed and he replied..
So far so good.
Old Apr 3, 2009 | 04:56 PM
Chuck1's Avatar
Chuck1
I got the rod off e-bay but the heim joints (not ball joints) I bought at my dealer. I didn't think missing the length a bit would make a differance and like I said it upshifts slick. We'll see how it does a few more test drives. I will take a look at the levers to see how vertical they are. To bad the service manual doesn't detail how to set the linkage.
Old Apr 3, 2009 | 05:01 PM
n8dc's Avatar
n8dc
The only adjustment on the linkage is to suit your foot and riding style. I guess this could be taken to an extreme but its pretty much a comfort setting Foot under the shifter and foot over the shifter of if you use the rear ...
Old Apr 3, 2009 | 05:06 PM
Ram's Avatar
Ram
It obviously your boots. You need down shifting boots. Or an adjustment of the ones you currently have. Do you know of cobbler in your area. Most have the TSB to do the down shift updates to older model boots!
Just kidding, I don't have a clue why its doing that. Mine works well both ways after adding a shift linkage.
