Help with Broken Throttle Grip Sensor
Old Apr 9, 2009 | 07:41 PM
woodworker_11's Avatar
woodworker_11
Default Help with Broken Throttle Grip Sensor
I have a 2008 Ultra Glide and have been working on installing grip warmers and along the way I broke the cable going to the throttle grip sensor.
There are some obious electrical wires that I could fix if those broke, but this is a thick black cable that attaches to the middle of the TGS. It doesn't look electrical and doesn't look like something that can be fixed.
If anyone has experience with the TGS and has any idea what this cable is for and if it can be repaired I'd appreciate a shout. Also, any ideas how much a new TGS costs?
These may be very expensive grip warmers
Old Apr 9, 2009 | 07:57 PM
dawg's Avatar
dawg
32305-08 $89.99
Old Apr 9, 2009 | 10:16 PM
woodworker_11
dawg,
Thanks for the info.
Do you know what that center cable is for or if it can be rapaired?
Old Apr 9, 2009 | 10:38 PM
dawg's Avatar
dawg
I don't know exactly what it is for. One of these days I'm going to have to call Tech Services and find out just what the gist is with it.
Old Apr 9, 2009 | 11:14 PM
kingkingking's Avatar
kingkingking
Hey the centre wires are for the grip heaters. Inside the black sheath is 2 wires that run right thru the TGS to the pins on the outside.
Old Apr 9, 2009 | 11:15 PM
EriCal's Avatar
EriCal
Woodworker. I am not sure which wire you refer to but the heavy wire is for heated grips and has no function for throttle control.
There is a rubber cap on the end of the tbw cartridge. Peel this cap off - you will be able to put it back on easily. You will see two small female connectors in the end of the cartridge after you remove the cap. These connectors connect to the heavy black wire to which you refer.
Strip the insulation from the heavy wires then do a ohmeter check for continuity to the small female connectors on the end of the cartridge. If complete you are ok.
If you are not going to install HD heated grips, the damage you describe is of no consequence.
E
09 RKC
07 RKC (The Wife's)
95 RK.
Sorce
Jun 9, 2019 10:37 AM
maximuswaximus
Jan 21, 2015 12:33 PM
Bradracer18
Jul 28, 2013 03:01 PM
Dynafrom818
Jan 6, 2013 02:25 PM
mhenning
Mar 23, 2010 08:24 PM
