Elite 3 tires
I've had good prices from this site in the past.
http://www.americanmototire.com/
We had the bike loaded down with tourpak and all and it bottomed out a few times. No damage though. My 07 is an SG WITH a 1 inch lowering kit. So I took the kit off and now no problems... 2 Inches may be too much for this tire. No problem before running the crappy 401s. They must be a shorter tire.
Just sayin. Regardless of this one thing the 160 works fine and fits fine.
It is wider than the stock D401 but it's skinnier than a D402 150. Kinda wierd.
It's also more expensive.
My advice... if just you want to tear up some miles worry free get the MU90B16.
It's near the same width and height as the stock 401 but with all the added benefits of the E3 tires.
If you want a wide tire and don't mind "close tolerances" get the 160-80-16. It looks awesome in there and rides fine if you don't lower your bike too much.
lp
have stock height shocks on my rk so theres plenty of travel, and i keep the air high too.
Hey thanks! Trying to be a little more informative here... Disclose everything you know.
So another thing NOT to worry about is the tire pattern on the front tire. When you get it mounted up, it will look backwards like the tire should have been mounted going in the opposite direction. It's normal and supposed to be mounted like that. I imagine once I get around to swaping my rotors around (again) to stop the brake squeal, that it will look totally assbackwards. I actually had someone walk up to me and tell me tire was mounted going in the wrong direction. I had to show them the Arrows to get them to believe me that it wasn't. Kinda funny. I got a beer out of it.
lp
