Suggestions for back rest?
Old Apr 21, 2009 | 07:00 PM
exitclub's Avatar
exitclub
Default Suggestions for back rest?
I have a 08 Ultra with a detachable tour pak. I was wondering if anyone knew if there’s a matching back rest that would line up with this mount. Wife won’t ride with me if I don't have the tour pak on. And I'm too lazy to keep putting it on. I know the bushings are 5/8' and the cross over measures about 10 3/4 on center. From front to back is 4 3/4'. I was told by Harley that this mount will not work with standard rest mounts. I guess if the rear cams work I could adjust the fronts to fit.
Attached Thumbnails Suggestions for back rest?-rear-tour-bracket-left.jpg   Suggestions for back rest?-rear-tour-bracket-top.jpg
Old Apr 21, 2009 | 07:12 PM
raines96+'s Avatar
raines96+
You have to purchase a forward docking kit from the dealer, not sure of the part#. Then you can get a Harley backrest that will mount using those cams and two of the cams for the detachable kit.
Old Apr 21, 2009 | 07:13 PM
dawg's Avatar
dawg
HERE's the docking kit matrix which will show you the required docking hardware needed for installing uprights, etc.
Old Apr 22, 2009 | 09:55 AM
JustDennis's Avatar
JustDennis
As the others said, you just need the other docking points. I had all of them installed on my 08 and regularly switch from backrest to tourpak or nothing.
tlar1540
Aug 6, 2013 09:59 PM
03 Fatboy
Mar 16, 2010 06:42 PM
BillinNY
Dec 31, 2008 01:58 PM
allikanbe
Jul 22, 2006 10:27 PM
hawnstar
Aug 25, 2005 03:21 PM
