Adjustable Backrest 09 UC question.
Old Apr 22, 2009 | 05:28 PM
Rubbit's Avatar
Rubbit
Default Adjustable Backrest 09 UC question.
How difficult is it mounting the hardware for the adjustable backrest with remote to a 09 UC? Does it require getting up under the rear fender, such as wheel removal? Order it online so i have not seen instructions yet. Any help would be great so i can know what to expect.
Old Apr 22, 2009 | 08:31 PM
hogginit's Avatar
hogginit
Waiting to put mine on. I have read the instructions and seems pretty straight forward except for the intruction sheet itself. Search for a recent thread on the site, it even has some pictures.
Old Apr 23, 2009 | 10:28 AM
KenFichtner's Avatar
KenFichtner
Easy to do.
Pull seat, follow instructions, 4 bolts. No need to remove anything but the seat.
Ken Fichtner
Old Apr 23, 2009 | 10:33 PM
Rubbit's Avatar
Rubbit
Originally Posted by KenFichtner
Easy to do.
Ken Fichtner
thanks for the help. ride safe
Old Apr 23, 2009 | 11:00 PM
ArgyleRider's Avatar
ArgyleRider
It took me about 30 minutes to install, including 10 minutes looking for the rear seat-to-fender screw that I dropped and lost. Make sure you take a look at how the seat cross-strap slips into the bracket when you take it off to remove the seat.
One thing I have noticed is that the backrest puts more pressure on my butt as I ride, because I sit straighter I think. Now I am in the market for a seat upgrade...
Old Apr 24, 2009 | 08:56 AM
WADELL's Avatar
WADELL
Just done mine. Bought it from a forum member. Remove seat, you will see 2 bolts in fender. Remove the 2 nuts. I had to drill a hole in the cross over piece of metal for the single bolt hole, no problem. Had to remove the spark plug wire clip holder from the factory heat shield so the adjustment control could be mounted. Be careful running the cable. The small locking tabs on the cable will break if you get them in a bind. Don't ask how I know. Fixed it with tie straps. Made my ride a whole lot more comfortable.
Old Apr 24, 2009 | 10:00 AM
HDJIM1158's Avatar
HDJIM1158
Like everyone above said....It's real ez and straight forward. Only bitch is lining up the controller under the heat shield. I am real happy with mine, although once set I have not adjusted it.
Old Apr 24, 2009 | 02:15 PM
Lowridin packer's Avatar
Lowridin packer
Very easy install - I would really look at the Mustang backrest instead if you have not bought it. It is a LOT nicer, and about the same cost. I had the adjustable Harley one on my last bike - this is a lot better - easier to adjust too and conforms to your back better
Old Apr 24, 2009 | 10:20 PM
hover's Avatar
hover
Smile
You mentioned this a while back, so I took your advice and bought the Mustang and am very happy with it. Easy to install and easy to use.
Old Apr 25, 2009 | 10:14 AM
Rubbit's Avatar
Rubbit
Sent you a PM.
Gordon65
Jun 13, 2014 12:05 PM
TRoper
Sep 17, 2009 12:05 PM
andrewj
May 22, 2009 07:59 PM
MickeyB
May 17, 2009 09:23 PM
