electrical problem
Old May 8, 2009 | 08:21 PM
scottsultra's Avatar
scottsultra
Stage I
Default electrical problem
I was riding my 05 ultra classic and for no reason my gauges went dead.
My bike runs great, I have 37000 miles on it. I was going 55 mph it started to rain I looked at my speedometer all my gauges stopped working. The check engine light does not come on at all to do a system check. When the gauges went out the security light came on. The high beam indicator light works, the tach and speedometer lights work but the gauges do not. The cruise control works but the cruise indicator light does not work. The fuel, oil pressure, bolt and air temp gauge lights do not work. My bike continued to run fine. I turned it off and restarted it and the gauges still did not go back on. I changed all fuses still nothing.
I can not figure out why this happened or how to fix it, any ideas???
Old May 8, 2009 | 08:31 PM
hogbag07's Avatar
hogbag07
Pull fairing and check earth wires around gauges.
Old May 8, 2009 | 08:47 PM
t150vej's Avatar
t150vej
All the gauges and their respective lamps, with the exception of the clock (if so equipped) are fed by a common wire which draws power from the accessory breaker via ignition switch.
'bout all I can offer.....
the_enforcer
Electrical/Lighting/Alarm
Jun 7, 2016 06:13 PM
bullet33912
Sep 18, 2014 12:30 PM
czxm94
Jun 26, 2012 08:11 PM
flhal05
Nov 16, 2009 07:56 AM
RGB KGB
Jul 16, 2005 02:09 PM
