Starter problem, 103 engine, Need advice.
Old May 24, 2009 | 11:30 PM
johnharley's Avatar
johnharley
Originally Posted by mhud
I had a HD 103 stage II installed a few thousand miles ago. When the weather got warm I also had occasional hard starts. I read a post here suggesting to hit the starter button as soon as you turn the key; I was amazed it works every time. Try it, you may find it solves your problem too.
Thanks, I will give that a try.
Old May 24, 2009 | 11:40 PM
johnharley's Avatar
johnharley
Thanks for the input. My problem is not the battery. When the starter kicks out then back in it makes a pretty bad metal on metal noise. It does not have any compression release installed. I had the dealer install the Upgrade 103 kit. Does the compression change much with that? What is the going price for a Hi torque starter?
Old May 25, 2009 | 03:42 AM
kingkingking's Avatar
kingkingking
Good to see the stealer is giving you the right advice. Time to find a new dealer me thinks...
Old May 25, 2009 | 05:54 AM
EG Ultra Classic's Avatar
EG Ultra Classic
I believe the dealer gave you the correct advice. Go with the CR's. That stock starter motor will really spin the 103" with the CR's down. One word of advice, though, when hot, always wear gloves to push down the releases, otherwise you can get a burn especially if you miss and push down on a head bolt trying to engage it. That DON"T WORK!!!!
XTrooper3936's Avatar
XTrooper3936
The compression does go up and often enough to create issues. You have two things going on. First, just increasing the displacement alone will increase the compression because of the increased volume of the A/F mixture. The second and bigger factor is that the Screamin' Eagle head gaskets that are included in the 103 kits are thinner than the stock ones and this, of course, increases compression as well.
Regarding hi-torque starters, the Tech Cycle 1.4kW starter I bought listed for something over $500. I found it on eBay for around $330 shipped. It's the same size as the stock starter, so they're are no fitment issues. It bolted right in without a problem.
Old May 25, 2009 | 06:14 AM
nocages4me's Avatar
nocages4me
Do a search I stumbled across another thread about this but I can't seem to find it now. Long story short I had a similiar problem. It sounded like my engine was going to explode sometimes. I read on this thread that when you start the engine's with the 103 kit, that as soon as you flip the run switch pull in the clutch and hit start. It said no to wait for the fuel pump to finish because something to do with the mapping at start up was different. I have tried it and haven't had the problem since maybe 50-75 starts since I tried this. Hope it helps and good luck...
Old Mar 18, 2010 | 10:44 AM
MC Chief4's Avatar
MC Chief4
6th Gear
Default 103 Starter
I own a 2010 Ultra Limited. My bike is ewquipped with the 103 engine as standard equipment and it had the compression release installed as factory equipment. I have been an equipment mechanic for years and it appears the release is needed. My engine will nearly stop the starter right before ignition.
Old Mar 19, 2010 | 12:10 AM
meveratt's Avatar
meveratt
This was posted by another writer once, and I have found it to be absolutely true. If I let the engine light go out when doing a hot start, I get a heckuva bang from the starter. If I turn on the ignition and hit the starter right away, it fires up perfectly with no bang. I have tested this over 22,000 km, through two hot summers, and it works every time. Try it!
harley_jeff
Exhaust System Topics
Jul 17, 2013 08:04 AM
pomeara
Feb 1, 2012 07:35 PM
uptop42
Sep 23, 2010 08:20 PM
johnharley
Screamin Eagle CVO Models
30
Aug 4, 2010 10:02 PM
paco ritter
May 7, 2009 02:34 PM
