left turn signalcoming on at random
Old Jun 7, 2009 | 04:23 PM
gilly.0038's Avatar
gilly.0038
Stage III
Default left turn signalcoming on at random
please help,I have a 04 ultra and left turn signal just comes on at random.I replaced all the bulbs and that didnt help. I hate to have to take it in for this,please help
Old Jun 7, 2009 | 04:29 PM
Captain Itch's Avatar
Captain Itch
Sponsor
If the bulbs come on I would not have replaced the bulbs,after all they are working. I would lean toward the switch itself.
__________________
www.Captain-Itch.com
Old Jun 7, 2009 | 04:37 PM
hogbag07's Avatar
hogbag07
Have you change the bars lately it sounds like there's a pinched wire in the hand controls on the left side or as captain itch said it could be the switch
Old Jun 7, 2009 | 04:40 PM
emwolb's Avatar
emwolb
yes, both previous replies probably apply to your situation. a pinched wire, or something in the switches is shorted out in the housing. easy to find, if you can see the problem once you remove your switch housings. will most likely show as a burned or smoky area inside the switch housing.
Old Jun 7, 2009 | 07:07 PM
notlost_nc's Avatar
notlost_nc
I'd cover that front lens up while you're troubleshooting.....don't want some bluehair to think your turning when you're not.
Old Jun 7, 2009 | 07:14 PM
ranger56528's Avatar
ranger56528
My 01 EGC the blinker would just come on and I had to hit the switch to cancel it the the other one would do the same.....Took it in and they put a new modual in it(warrenty),said it was going in to sidecar mode....ok whatever I said.....now both flash 3 times before I start it...bike runs good so I ingnore it now...
Old Jun 7, 2009 | 07:24 PM
1of2's Avatar
1of2
"Moderator"
I had the same problem on my old bike. It was a bare wire from when they relocated the rear blinkers. Check the wiring first from whatever has been messed with. It's annoying as hell isn't it???
Old Jun 7, 2009 | 08:13 PM
mhenning's Avatar
mhenning
This happen on my 05 road king a couple of weeks ago. I had new bars put on so I thought pinched wire. Nope the switch was bad! Not a good feeling when it comes on all by it's self! Good luck.
Lost Again
Apr 9, 2025 06:38 PM
acchd
Electrical/Lighting/Alarm
May 13, 2020 05:36 PM
rainsong
Sep 5, 2018 09:46 AM
fredtman
EVO
Oct 29, 2017 10:27 AM
oldhippie
Apr 22, 2015 08:34 PM
