Re-install front fairing
Old Jun 8, 2009 | 11:35 AM
dkitch's Avatar
dkitch
Default Re-install front fairing
Has anyone heard about heavy duty inserts that replaces the brass threaded bosses on the fairing to tightup around the windshield. The standard ones seem to pull out if you tighten just alittle too much. would lioke the part number thanks.
Old Jun 8, 2009 | 11:40 AM
n8dc's Avatar
n8dc
your dealer should have the part number.. Im not sure they are heavy duty but I believe they are redesigned to screw in instead of being a molded in insert as stock.. Some good super glue or better yet some good epoxy should fix the ones you have ... Just remember its a brass insert in plastic holding the upper fairing and windshield together... No need for 100 lbs of torque
Old Jun 8, 2009 | 01:38 PM
acchd's Avatar
acchd
Someone posted pn recently and I wrote it down. It's 16585-96.
Old Jun 9, 2009 | 01:21 AM
emwolb's Avatar
emwolb
there must have been a design improvement on the newer models, cause i am not too gentle when tightening the three windshield screws. just that i don't get carried away either. good luck and hope you get it working for you.
Old Jun 9, 2009 | 05:18 AM
mainshaft's Avatar
mainshaft
My buddy has the same issue, thanks for the part number acchd, I'm going to pass it along to him.
apetterez
Jul 31, 2014 09:40 PM
Teardrop
Aug 4, 2013 01:58 PM
trackadaptor
Jul 17, 2013 01:35 PM
ssihogdog
Aug 7, 2007 05:21 AM
JC650
Jul 17, 2007 12:36 AM
