Ape hangers coming loose!!!
Old Jun 18, 2009 | 08:55 AM
klinker24's Avatar
klinker24
Default Ape hangers coming loose!!!
I recently had a set of ape hangers installed on my Heritage Softail Springer Classic and they wont stay tight. I have tried to tighten them several times and after a week or so they come loose again. Does anyone have any ideas that I could try to get these things to stay tight? I have tried Locktit and it doesn't seem to help. Thanks for your help!
Old Jun 18, 2009 | 09:00 AM
FunkyNova66's Avatar
FunkyNova66
Does the ape hangers have the ridges on where it meets the neck? I have heard several different remedies for this problem. One is using sand paper folded in half with the sand side facing the surface area between the neck and handle bars. I've also heard of people cuttng a strip of coke can and inserting the aluminum strip between the bars and neck. Maybe some others can chime in with better solutions. Good luck.
Old Jun 18, 2009 | 10:00 AM
Road Ranger's Avatar
Road Ranger
Rather than use a strip from a coke can, I think you would have better success using a strip off a beer can. Either one will work fine...I ended up taking the clamps off mine and grinding a couple thou off them to get a little more squeez on the bar...haven't had them come loose since.
Old Jun 18, 2009 | 10:07 AM
FLAMED96's Avatar
FLAMED96
Take a piece of 320 grit emery cloth, fold it over so that the grit is on the outside and sandwitch between the bars and clamp, works everytime.
Old Jun 18, 2009 | 12:32 PM
Twist n Smoke's Avatar
Twist n Smoke
Did you powder coat them? If so you will need to remove the powder from the bars where the "ridges" are at.
Old Jun 18, 2009 | 09:42 PM
klinker24's Avatar
klinker24
Thanks for the help. I will try these solutions and see what happens. I will keep you posted.
Old Jun 18, 2009 | 09:48 PM
Chumplestilskin's Avatar
Chumplestilskin
I thought that was for when the cops rode by, you could lower then to legal height while driving?
Old Jun 18, 2009 | 09:53 PM
MJ's Avatar
MJ
When mine started doing that, I just cut a couple pieces of a latex glove, like surgical gloves and wrapped around the bars at the clamp. Hasn't come loose since.
Old Jun 18, 2009 | 10:03 PM
xtremechopper's Avatar
xtremechopper
I have always pinned mine once I get them in the right position. You can either use a roll pin or allen set screw.
Old Jun 18, 2009 | 10:20 PM
Big Poppa Pump's Avatar
Big Poppa Pump
The beer can trick works great. I used some Mickey's.
jquest
Sep 24, 2018 10:55 PM
stbobshadow
Jan 27, 2015 01:53 AM
groverhd
Nov 9, 2012 05:51 PM
BlueNoser
Sep 26, 2010 05:12 PM
chinbagger
Oct 29, 2009 09:42 PM
