Terry Terminal 3
Old Jun 30, 2009 | 08:57 AM
WindDamage's Avatar
WindDamage
Default Terry Terminal 3
Would like to hear from anyone using the TERRY 3!!!
1. If and how it helped?
2. Did you have it Dynoed after install??
3.What other mods do you have (pipes/air cleaner, cams)???
THANKS
4.I want to do my mods ONE time and then RIDE RIDE RIDE !!!!
5.I have a stock 09, looking for mild upgrades that won't cost a pile of $$$.
Old Jun 30, 2009 | 10:09 AM
wildeano's Avatar
wildeano
i had a terry tv3 on my 07 e-glide, for about 2 months, the indy that put it on could never get the idle right as there are no adjustments on the module. there for you can not tune it with a dyno run. as for the idle, at one stop light it would idle at 1100 rpm and 2 miles up the road it would idle at 850 rpm. i took it off and had a pc3 put on with a dyno tune. there are a couple of other threads on here about the tv3, some others on the forum had idle problems also... imho, go for the power commander or something else
Old Jun 30, 2009 | 07:47 PM
GEORGEW's Avatar
GEORGEW
I must say I had a Terry 2 on a 02 softail,,,It worked wonders
The Bike ran a lot better
MPG went up
AND ONE MORE THING I COULD SMOKE A BUDDY OF MINES FATBOY AFTER HE INSTALLED A SET OF S&S 510 CAMS
Old Jul 1, 2009 | 01:36 PM
WindDamage's Avatar
WindDamage
Bump !!
Old Jul 1, 2009 | 03:15 PM
SSJ's Avatar
SSJ
I have a TV11 the 3's are better, mine has been great no problems with Supertrapps and Doherty PowerPacc I like you wanted a one time thing especially since there are no close dyno's where I live, I get 45-47 consistant with 55-57 above 2000 ft.
Old Jul 1, 2009 | 06:02 PM
CDN. RG's Avatar
CDN. RG
I have a tv 2 and it seems to work good,you say the 3 is better, just curious to what the differences are between the two
Old Jul 2, 2009 | 11:10 AM
WindDamage's Avatar
WindDamage
I called TERRYCOMP ,,TALKED TO A TECH ,, WAS TOLD THAT AIMAG.COM
WAS TESTING THE TERRY 3,, AND RESULTS WILL BE IN THE MAG. SOON!!
Old Jul 2, 2009 | 02:42 PM
SSJ's Avatar
SSJ
Thumbs up
Was thinking just by looking the 3 had less connections, but not according to the instructions but it did add a 02 sensor, the 3's are only for throttle by wire bikes.
fordhd2005
11
May 13, 2024 07:54 AM
skifly86
2014-2024 Touring Models
11
May 7, 2018 04:14 PM
lhgdale
Milwaukee Eight (M8)
31
Apr 13, 2018 03:51 PM
slammed05fatty
Dec 15, 2014 07:25 AM
mkultra
Apr 24, 2006 12:41 PM
