oil leak advice needed
Old May 20, 2006 | 10:44 AM
msbhvn's Avatar
msbhvn
Default oil leak advice needed
I have noticed that I am getting some oil on the inside of the left muffler and can't see where it is coming from. While setting it will leave a few drops on the garage floor, marking it's teritory I guess, and wiping under the muffler it will be about at the axle where the drip comes down.
Thanks
Old May 20, 2006 | 11:08 AM
MACK's Avatar
MACK
Default RE: oil leak advice needed
If it is not from the primary it is probably the outpit shaft inside the inner primary. big job covered under warranty if the bike still has warranty.
Old May 21, 2006 | 03:56 AM
RBJones's Avatar
RBJones
As Mack said, check the primary first by putting a allen wrench to the bolts. Those bolts have a tendency to back off slightly over time and allow a little seepage that may be working it's way back in the wind to your muffler. Use a torque wrench or just snug them up if they're loose and see if that fixes the problem.
Old May 21, 2006 | 01:51 PM
websterdan's Avatar
websterdan
Mine did same thing around 1k. I thought output shaft seal, inded up being starter/jackshaft seal. Lean bike on stand and look under from right side, where trans and starter attach.
Old May 22, 2006 | 09:17 AM
msbhvn's Avatar
msbhvn
Took it in to the dealer on Saturday and believed to have tracked it down to the left side shock. We will see.
Old May 22, 2006 | 10:02 AM
100thRK's Avatar
100thRK
That is interesting. Would not have thought that would be the source.
ORIGINAL: msbhvn
Old May 22, 2006 | 12:49 PM
Big Ted's Avatar
Big Ted
When I first got my bike in 2003 one of the shocks started leaking right away. Had to have it replaced under warranty.
06Sportster1200
Nov 1, 2011 01:20 PM
BB
EVO
Oct 31, 2011 07:00 AM
Night Crawler
Jun 28, 2011 12:59 PM
Fastfwd
Jan 14, 2011 02:45 PM
michiganladyrider
Jun 16, 2007 09:43 AM
