ABS warning!!!
Old Jul 30, 2009 | 08:56 AM
tmblweed's Avatar
tmblweed
Give Kawasaki credit on this one...the ABS and linked braking system on the new Voyager is disabled below 10 mph or so.
Old Jul 30, 2009 | 09:23 AM
fevest's Avatar
fevest
Read your manual, the abs does not work below, if I remember correctly 8mph.
Old Jul 30, 2009 | 09:27 AM
Iamopie2's Avatar
Iamopie2
ABS vs non-ABS...here we go again
Old Jul 30, 2009 | 09:29 AM
Jinks's Avatar
Jinks
ABS didn't lock your wheel, you did. ABS *releases* the brake. Expecting the other driver to do something stupid & leaving yourself room to avoid the problem will do more to keep your fenders straight than anything an engineer can put on your machine.
Old Jul 30, 2009 | 09:33 AM
Jim Dawson's Avatar
Jim Dawson
Originally Posted by rides99fatboy
.....I assume the "button" on the rotor is the what the sensor in the caliper detects.
....So is the sensor looking at the wheels or the rotors?
That "button" on the rotor is what make the Brembo rotors "semi-floating" rotors, it has nothing to do with ABS. The ABS sensor detects it's speed by detecting the speed of the special left wheel bearing.
Old Jul 30, 2009 | 09:52 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Originally Posted by Texas Fat Boy
That sucks, but ABS doesn't work (become active) at speeds that slow.
Originally Posted by tmcgeesr
.......................... Its my understanding its suppose to work at all speeds..........................
To quote the '09 owners manual on page 58:
"The wheels won't lock until the end of the stop when the motorcycle reaches approximentely four miles per hour and ABS is no longer needed."
I knew it was some slow speed.
Old Jul 30, 2009 | 09:58 AM
Twinrider's Avatar
Twinrider
The speed sensor on the wheel is to detect slippage of the wheel. Its my understanding its suppose to work at all speeds.
I agree with the questionable service of "Harley" ABS on a washboard surface. I have experienced that several times. Overall I think its pluses out weigh its minuses.
I've been riding for over 40 years, and I have been riding ABS since the early 80's on BMW's. They went through 3 generations of ABS before they got it right. Apparently Harley is on generation #1.
I agree. Harley's system is like BMW's first generation ABS. There's far too much time between pulses, which can result in situations like the OP faced.
Old Jul 30, 2009 | 10:17 AM
cbears's Avatar
cbears
Man that sucks for sure!!! Have the ABS checked out, I've had no such issues with mine, had to stop pretty quick a couple of times.
Old Jul 30, 2009 | 10:18 AM
88b's Avatar
88b
I was going to say 5 mph but it could be 8 mph. If it worked at all speeds you could never stop.
here's one a dealer fixed for a friend, after he confronted the dealer he's now got an 09
Old Jul 30, 2009 | 10:47 AM
htc's Avatar
htc
Mine is on all the time. I double checked that. Means skid marks after skid marks until it stops. Took me 35 years to face situation like this so I wouldn't consider myself as careless driver. AND being experienced driver ;-) I think you turn inexperienced when its raining and the deer is suddenly running in front of you. THEN you might need ABS. In dry predictable conditions every one of us beats ABS, I think ;-)
So pros and cons.
