Bar Change ??
Old Aug 10, 2009 | 02:56 PM
modes's Avatar
modes
Originally Posted by 07FLHRCMarinePatriot
You're assuming you have to use a kit (which requires pulling the connectors). You could, instead, just snip and solder your own extensions in. The correct guage qire at the auto parts store and shrink wrap at Walmart cost less than $10. Here's my DIY bar swap in case any of it could be of use to you: https://www.hdforums.com/forum/touri...e-install.html
You still have to pull the connector ends to be able to pull the wires through the handlebars.
Adam
Old Aug 10, 2009 | 03:04 PM
harley0711's Avatar
harley0711
taking the connectors abart is a breeze - I have done it so many time, I could do it in my sleep... I am guessing you will not have any problems, get the service manual and if you do need some help... PM me and I will give you my home number, I can talk you though the connector over the phone... its that simple...
Old Aug 10, 2009 | 03:05 PM
Twist n Smoke's Avatar
Twist n Smoke
I did mine on my 08 SG and 1 thing I would add it to take a dremel or something simillar to smooth out the edges of the internal wiring hole in the bars. Don't ask me how I know.
Old Aug 10, 2009 | 03:26 PM
hounddog1257's Avatar
hounddog1257
Awsome thanks and i will take you up on that when i get ready to do the swap!
Old Aug 10, 2009 | 04:24 PM
07FLHRCMarinePatriot's Avatar
Adam
Not so. You cut above the connectors at the bottom end (in the nacelle) , solder your new wires at the "new" top end of the wire, run them through the bars, then solder back to previous connection points. Just label your new wires (before running thruogh bars) with the appropriate colors to make mating easier.
Old Aug 10, 2009 | 04:37 PM
MrHog's Avatar
MrHog
Originally Posted by hounddog1257
Thanks for the replies, i am pretty handy so i do believe that i am going to attempt this. I may wait till winter so if it does end up taking a bit longer it wont cut into my riding time!
The bars I installed had more rise and pullback, and the wires were too short to run internally. I had 16 wires to cut, extend and heat shrink wrap. I did my install last Winter, but only took a few hours and a few cold beers. You cvan try and tackle it one rainy day.
Sparra
Electrical/Lighting/Alarm
Feb 17, 2015 06:25 AM
petefwa
May 7, 2014 07:57 AM
Shark Ride
Jan 24, 2011 04:52 PM
41inWV
Jun 23, 2010 03:19 PM
TOMMY M
Aug 11, 2009 02:19 PM
