2001 Road King intake manifold part number
Old Aug 24, 2009 | 11:20 AM
2K1FLHPI's Avatar
2K1FLHPI
Default 2001 Road King intake manifold part number
Does anyone have the part number for the intake manifold for a 2001 FLHPI Road King police edition? Mine apparently is cracked.
Old Aug 24, 2009 | 11:27 AM
jdreed520's Avatar
jdreed520
Is it the MM EFI unit or Carb?
Old Aug 24, 2009 | 12:14 PM
2K1FLHPI's Avatar
2K1FLHPI
The bike is EFI.
Old Aug 24, 2009 | 12:23 PM
jdreed520's Avatar
jdreed520
Originally Posted by 2K1FLHPI
The bike is EFI.
Is it the MM efi or the Delhi Efi? The MM is kinda rectangular in shape and it had 2 fuel lines coming out of the tank.
Old Aug 24, 2009 | 12:37 PM
Firetender's Avatar
Firetender
I think you mean MM ECM or Delphi ECM. The MM uses a dual-throat intake and the Delphi uses the single-throat intake. The ECM is what Delphi makes for the newer system, MM is still a major contractor with HD and likely manufactures the other parts for both systems. If the bike is an '01, the EFI uses the dual-throat intake.
2K1FLHPI's Avatar
2K1FLHPI
Eee. Dunno. I haven't taken it apart to see for myself. When I had the bike in at the stealership last week for some service, they mentioned the cracked intake manifold.
Let me get back to you once I get a chance to have a look.
Old Aug 24, 2009 | 12:40 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
Well you need to find out if you have the Magnetti Moreli fuel injection or the Delphi. I think 2000 was the last year for the MM and that from 01 and on, they have the Delphi system.
Old Aug 24, 2009 | 01:17 PM
jdreed520's Avatar
jdreed520
That was what i could not remember...was what year the Delhi started i was thinking it was 01 but thought maybe it was late 01 so then it would mean 02....
Old Aug 24, 2009 | 01:20 PM
jdreed520's Avatar
jdreed520
No i was refering to the EFI unit itself not the ECM....even though they are different. But the MM EFI is like somebody else said a dual throat and the Delphi is a single throat. I have both and that will make a diferance as to which one he needs and the cost. But like somebody else said they thought the delphi stated in 01 but that was what i could not remember.
Old Aug 24, 2009 | 03:51 PM
Firetender's Avatar
Firetender
Harley-Davidson started using the Delphi ECM with their model 2002 EFI systems. The Magnetti-Marelli ECM was used until 2001. A 2001 model uses the dual-throat intake. This part was changed in 2002-and-up. The system is called a "Magnetti-Marelli EFI system" although it's the ECM part that is made by Magnetti-Marelli or Delphi, not the other parts. The part needed is the dual-throat intake.
