What tuner did you use on your bike? I just installed s&s 551g's and switched to a thunderheader on a 2011 SG 103 I have the sest just wanted to get a rough idea of what my numbers may look like. Thanx Lou.
I've had two bikes dynoed at two shops here in the Bay Area. I can say without a doubt that R.E. Engineering in San Jose will get you dialed. Under the curve and throttle response is off the chart compared to the other shop. Also my idle mixture isn't so rich it makes my clothing stink.
Both shops did great on WOT runs. But in my opinion throttle response, crisp throttle, is the most important thing.
I noticed that the dyno sheet that you posted was from Rc cycles and you recomended Re engineering any paticular reason? I sure like those numbers on that sheet you posted, I would be very happy with those numbers
