First Harley Need Help Please
Old Aug 31, 2009 | 11:02 PM
cdesero's Avatar
cdesero
Default First Harley Need Help Please
Purchased my first harley from a good friend. Bike has had nothing but the best care. But i need some info i have been doing a good amount of reading about the Rear of the bike wandering and belive me it does. Tires are at the proper PSI and new last year they are Dunlop 402.
Would different tires help?
True Trac set up or simular stabilizer?
STA-BO bushing change ?
Thanks For any info or opinion
It is a 2000 Ultra With 17000 miles
Old Sep 1, 2009 | 01:12 AM
RK4ME's Avatar
RK4ME
Is the rear wheel properly aligned? Are the swing arm bushings OK? I'd put that bike on a stand and check every nut and bolt, frame and swing arm too. There IS some frame flex on pre-'09 FLHs with rubber-mounted engines. Rain grooves on the freeway don't help either. Enjoy your Hog.
Old Sep 1, 2009 | 06:36 AM
RoadKingLou's Avatar
RoadKingLou
I would bring it to HD and have it checked out ASAP
Old Sep 1, 2009 | 06:45 AM
petdoc94's Avatar
petdoc94
Depending on your situation $ wise, take it to have checked out for sure. I try not to go to the STEALER for much, I have found a shop in my area that was opened by a certified Harley mechanic that has the lowest shop fee's and such in my area that I use for everything....It has been in business now for years and is used by alot here..But don't play get it checked by someone that can tell you what is wrong, so it doesn't cause you to go down....
Old Sep 1, 2009 | 06:49 AM
Jinks's Avatar
Jinks
Look at some of the threads here on stabilizers. All pre '09 bagger frames need a stabilizer. The choice of which one is yours depending on your wallet, road clearance, & ease of installation. You only need to limit the small amount of "rear stear" induced by the rubber mount system. There are some very large threads, do a search.
Old Sep 1, 2009 | 07:08 AM
cmhfguy's Avatar
cmhfguy
Does it wander on all types of roads? It could be wandering due to tire ruts in the road.
Old Sep 1, 2009 | 07:52 AM
piasspj's Avatar
piasspj
None of the bikes need a stabilizer, but I believe they do reduce that wandering feeling. I don't have a stabilizer on mine.
I feel a little bit of wander only if I'm changing speed or lines while in a curve. I've gotten used to it.
I agree with RK4ME, check the bike first. Also ask you friend if it has always felt like that.
Old Sep 1, 2009 | 11:09 PM
cdesero's Avatar
cdesero
Thanks for the info and help think i will be calling the shop to get it looked at
Old Sep 1, 2009 | 11:42 PM
MWM's Avatar
MWM
I a 2008 Ultra and had a 2005 Standard. I corner real hard in curves (metal scraping) and have the infamous wheel hop/wondering happen on most of them. It's just in the curves and with my hard driving though. Normal driving isn't a problem at all.
Rodtrain
Nov 14, 2013 01:29 AM
iaharley
Jun 11, 2013 10:24 PM
62 Basket case
Mar 8, 2010 07:54 PM
62 Basket case
Mar 7, 2010 05:42 PM
Memo7070
Jan 1, 2010 07:23 AM
