I've recently had the front tire replaced on my bike and I feel used. I hate paying for something I can do myself. I generally do all my own work but when it comes to tire changing, I don't have the tools and it pains me to pay a shop to replace my tires. I'm a firm believer that "He who dies with the most tools/toys wins!" so I have a well stocked shop, but tire irons, bead breakers, and balancers... I don't have. My back tire will need to be replaced again by the end of the season and I really don't want to pay to have it done. What are you guys using for tire levers, bead breakers, balancers? If you can suggest a link to some quality tools I would appreciate it.
You'll need the following:
1. Tire irons
2. Rim savers
3. Dyna beads (for balancing unless you take them to a Indy and have them balanced)
It really is an easy job if you have mechanical knowledge. a H-D service manual for your model, and a cycle lift or jack.
I saved enough money doing my own one time, to buy the tools to do it.
As for the bead breaker, you can use two 2 x 4 's and it gets the job done really easy. The setup I used is in the picture below.
Just be sure and block up the tire and wheel so your rotor or pully is not touching the floor. Step your right foot on the ouside of the tire/rim while pushing down on the 2 x 4 and POW, the tire pops off the bead. If you want a video on it go to YouTube and search for "Redneck Bead Breaker"
Hard to believe for the 20.00 or 25.00 it wouldn't be easy, less chance of damaging a rim, not balancing it correctly and just take it to a Dealer or Indy? As far as balancing a tire and rim combination you can do it with a home mad stand and a pipe. It's a form of static balancing. You find the balance point and thats where the weight goes.Search the internet, it does work just fine. Learned it from a road racer. Most of them can't afford balancers and that's how they do it. (Amature class)
Along with that get 4 nice 12" tire irons, 4 rim protectors, a lever handle bead breaker (not the wrench operated C clamp type) a sheet of 1/4 oz stick-on weights. I use soapy water as a lube for removing and a spray tire lube for mounting.
FWIW I know a number instances where 2-3 riders go together to buy a balancer and tire changing machine, which makes sense.
the e3`s and all the tools from jake wilsons for $350, then i bought the cyclehill tire changer for $365 and still saved $100 bucks now i change my own!
Once a rim is balanced you shouldn't need to rebalance every time you change a tire. Remove old tire, leave any weights on the rim, and line up the dot on the new tire with the stem. Or you could use Dyna Beads and remove the old weights. Either way a balancer is not needed.
I'm not trying to start some kind of fight, but I have to disagree with the above post. I mount my own tires. I have used dyna beads with good results, and also used stick-on weights using a spin balancer.
I know that the last set of tires I mounted for my Ultra (Dunlop E3's) balanced differently than the D402's that I replaced. It wasnt much of a difference. If I remember right I had about 1/4 oz less weight on both front and rear and had the position change by about 3 or 4 inches on the rear wheel.
Yes, the tire placement is very important. Will 1/4 oz make a difference?? Doubtful, but If I am going to do it, I am gonna do it right. JMO
