question about a tourpack
Old Sep 13, 2009 | 02:22 PM
john62's Avatar
john62
Default question about a tourpack
Hi guys I hope you can answer a question about the differance between a 06 and 09 tour pack . I bought one on ebay and I seem to have holes on the bottom that don't line up with my detachable mount. My ride is an 06 fhltpi. I realise that I will have to lift the tour pack with bushings so the saddle bag lids will operate.
Old Sep 13, 2009 | 02:47 PM
dawg's Avatar
dawg
Originally Posted by john62
Hi guys I hope you can answer a question about the differance between a 06 and 09 tour pack.... holes on the bottom that don't line up with my detachable mount.
You just answered your own question.....different mounting holes
Old Sep 13, 2009 | 02:49 PM
gambler's Avatar
gambler
If everything else works and fits, use a drill press and make your own holes in the detach bracket.
bigskyhd's Avatar
bigskyhd
The tourpaks for 06 and 09 are basically the same. If you bought a used one, the holes probably don't line up because it had a different mount. (Permanent vs Detachable or visa versa) Or maybe the previous owner just rigged it up to fit on a different rack. The basic tourpak is the same, and you'll probably have to adapt for you mounting rack, and fill the other holes. Hope this helps.
Old Sep 13, 2009 | 08:35 PM
Harleypingman's Avatar
Harleypingman
The '06 detachable rack will have a U-shaped chrome tube. Use it to mark the five holes you will need to drill in the tour pak.
The question is where, exactly, should you locate the holes. Suggetion: take a look at the relationship to the back of the U-tube and the back edge of the tour pak on an '08 or older bike with the tour pak mounted. That distance from the back of the U-tube to the back edge of the tour pak should give you a good reference point.
You will be drilling through the plastic of the tour pak and the metal base bolted inside. Not difficult to do (I did mine recently to use the Milwaukee Bagger two-up detachable rack that uses the HD mounting hardware for the passenger backrest/solo detachable rack).
Good luck with your project.
Perrin123
May 1, 2017 06:14 PM
Bubba Zanetti
Feb 21, 2016 07:03 AM
owen06
Aug 18, 2011 12:57 AM
slojoh
Aug 31, 2010 11:14 AM
HDV-GLIDE
Apr 30, 2010 11:11 PM
