Which cam?
Old Nov 3, 2009 | 06:43 AM
  #41
Wally's Avatar
Wally
Originally Posted by Kustomhd
se255 is my preference you will be happy with them... I have installed dozens of them on customers bikes and all are happy.
What's the difference between the 255,s and the 253's?
Old Nov 3, 2009 | 07:24 AM
  #42
Ribitt's Avatar
Ribitt
Cool
well I have almost the same set up and here are my andrews 26 dyno.
________________________________
07 UC, Rinehart TD's, SERT, SE A/C
S&S Geardrive, Andrews 26 Cam
Old Nov 3, 2009 | 09:32 AM
  #43
StreetGlidinFreak's Avatar
StreetGlidinFreak
I believe the 253 and 255 are the same, the 255 is for the newer style cam chain in the 07 and up.... not positive though.
Old Nov 3, 2009 | 10:33 AM
  #44
iclick's Avatar
iclick
They are about as different as cams can be, IMO:
SE-253
Lift: .538"/.538"
Duration: 240°/256°
Intake: 7° BTDC/53° ABDC 0.119"/.158"
Exhaust: 59° BBDC/17° ATDC
SE-255 .550"/.550"
Duration: 211°/235°
Intake: 6° BTDC/25° ABDC 0.079"/.070"
Exhaust: 48° BBDC/7° ATDC
The intake close alone is enough to make a major difference in the low-end without increasing compression. IMO the 253's would be a poor choice if low-end TQ was a priority and stock compression was used.
Old Nov 3, 2009 | 11:03 AM
  #45
iclick's Avatar
iclick
Originally Posted by Steelknee57
If I read that right, he not only changed cams and exhaust, he made other changes as well? If so, I don't think it is a fair compairison.
I personally ride an Ultra and almost always go over 4,000 rpm just getting up to speed to merge on the freeway.
I see little practical difference. The headwork was the same, which I think would benefit the 6-6's more than the 255's since they are a peakier grind and the headwork will benefit higher RPM's more than lower. I would think it would likely hurt the low-end overall. The difference between Jackpot mufflers with stock head pipes vs. MO's with the Power Duals would not be clear to me, although I tend to think of the Jackpots as being the best-performing slip-ons available, all other factors being equal. They are not equal with the addition of the PD's, but I can't say how the two exhaust setups compare on the dyno.
Not trying to get into a debate on cams I'm no expert, but everything is a comprimise. Overall, from my personal experience and from the posters comments, seems that the Woods cam gives more grunt overall.
They do, but were likely not as strong in the extreme low-end and in the OP's opinion did not provide any performance increase "where he rides." It's all where you want the power to come in, and the 6-6's would clearly be best if top-end power was your goal. Keep in mind also that the 6-6 and 4° combo would've cost me $525 vs. $110 for the 255's. That coupled with my desire to increase low-end and midrange and the decision was a no-brainer, for me.
OBTW aren't the woods cams 380.00 retail? + 15.00 for a plus 4 key from T- Man?
I was quoted $400 for the cams and $125 for the gear plus shipping, but I would think an Andrews gear would work as well and is cheaper. FWIW the 6-6 + 4° gear was my second choice, and this combo lost out because of cost and based on dyno charts I saw the 6-6's would have decreased the extreme low-end somewhat when keeping stock compression. I was determined that at no point in the low-end would a TQ decrease be acceptable, and that alone eliminated the chances of every other cam available as far as I could determine.
Old Nov 3, 2009 | 02:25 PM
  #46
StreetGlidinFreak
Wupps....I was thinking about 203's wasn't I? Isn't that the cam that used to come with the 103 kits? Of course I could still be wrong on that. I can never find the specs for the SE cams.....where did you run across them ICLICK?
Old Nov 3, 2009 | 04:01 PM
  #47
Barrenmug's Avatar
Barrenmug
This might help you. Scroll down a little.
Old Nov 3, 2009 | 04:10 PM
  #48
StreetGlidinFreak
Cool!! Thanks Barrenmug! Huh...guess they actually made the 255's a bit bigger lift and different duration than the 203's learn something new everyday! That is a pretty good list of cam specs. LOL now I can do some comparing when I get bored.
Old Nov 3, 2009 | 09:48 PM
  #49
iclick's Avatar
iclick
You can download the HD SE catalog here. The cam specs are on p.43.
Bluesguy
2018+ Softail Models
25
Jun 17, 2019 03:08 PM
KevenC
Feb 15, 2017 10:23 AM
harley7316
Dec 14, 2013 09:17 PM
TODDNVAL
Feb 12, 2009 02:50 PM
Thrak
Carburetor Related
Oct 27, 2008 05:05 PM
