How imperative is it to install them? If needed, I think I can pick a set up in the morning.
Thanks,
Imperative? I wouldn't say imperative. If your bike is relatively new you'll be OK for a while. The taller you go the more imperative it becomes. Problem is that the cheap rubber ones they give you wear out quicker and taller bars speed up the process. You will have to take everything apart and do them again someday. I'd suggest picking some up. They are cheap enough, and you don't want to do the job twice.
Good luck! We are here if you need us...
Thanks Dew, I'm going to pick up a set today and just replace them Now while I'm doing the bars.
