Monkey Bagger Bars with Pics (Install)
Old May 26, 2013 | 08:33 AM
  #821
acchd's Avatar
acchd
The TBW stock sensor green plug is stranded wire........
Originally Posted by BigGelvis
As far as the TBW goes? I firmly believe it was better to buy the CVO kit and NOT splice any wires on that one. That totally eliminates any possibility of a splice failing down the road as it is solid wire from the grip sensor to the plug.
To each his own but as much money as you are spending of installing bars and as much of a PITA as it is, I would rather spend the extra $$ and make sure it is done right the first time then to have to pullit apart and do it again later or be stranded with a short in the TBW harness.
Old May 26, 2013 | 12:55 PM
  #822
BigGelvis's Avatar
BigGelvis
And?? What does that mean and what does it have to do with what I said? They are all stranded wires.
The CVO sensor kit has wires that are long enough to run all the way thru the bars with no splicing needed. Just reconnect the plug after pulling the wires.
Old May 26, 2013 | 12:59 PM
  #823
acchd's Avatar
acchd
If I had to explain u wouldn't understand.
Old May 26, 2013 | 01:08 PM
  #824
BigGelvis's Avatar
BigGelvis
No need to be a dick about it!
You make no sense at all. You quote me with an incomplete sentence and expect people to know what the **** you mean?
So what the **** does the green plug being "stranded wire" have to do with anything?
Old May 26, 2013 | 04:47 PM
  #825
Jswerve's Avatar
Jswerve
I like pickles...
Old May 28, 2013 | 05:47 PM
  #826
chopperrescue's Avatar
chopperrescue
4th Gear
Default Instructions
If someone would send me the instruction , many thanks ! mitchellchpr@yahoo.com
Old May 29, 2013 | 04:57 PM
  #827
TexasSG's Avatar
TexasSG
-sent
Old May 29, 2013 | 07:08 PM
  #828
ybnorml's Avatar
ybnorml
Originally Posted by Jswerve
I like pickles...
sliced, spears, dill, sour, or bread&butter.... on or beside your sandwich ??
Old Jun 2, 2013 | 05:09 PM
  #829
stepp's Avatar
stepp
6th Gear
Could someone send me the instructions, thanks. Corystepp@gmail.com
Old Jun 3, 2013 | 09:22 AM
  #830
TexasSG's Avatar
TexasSG
-sent
