Monkey Bagger Bars with Pics (Install)
1) Remove the radio
2) remove the passing lamps and rotate ( Tilt ) the fairing forward.
There is no reason to remove the tank unless you are replacing the front brake line, in which case a large % of guys do so that may be why you see them removing the tank.
As for me, I did not remove my tank until after I installed the new bars. Reason why was so I could make sure the bars did not hit the tank at full lock.
Most people won't have that problem but I have a 2" lift kit on my tank and even my OEM bars hit. So I had to make sure the new bars were adjusted perfect before removing the tank to install the brake line.
Another little tip for you.
After I got mine all back together, I must have knocked the bars out of adjustment a little. It would hit the tank when turning all full lock right.
I found that if I just remove the ignition and cover, I can access the front two riser bolts. I only need loosen those front two bolts to reposition the bars. I did not have to tilt the fairing forward to reach the rear bolts.
You meant the rear two riser bolts, right?
I call em front but rear is probably better to describe them.
And it was a torx wrench, T40 if I remember right.
Tbw had about 4" more wire, did not cut a single wire. Connectors stayed on the end of each wire no problems. Tbw did not have any issues with green plug.
Went +8 magnum black pearl upper front and mid lines as well as +8 clutch. Everything works as it should not a lot of slack but a little wiggle room just in case. I will say my least favorite part was taking off exhaust system for the clutch cable.
Did not bleed brakes abs works as it should. Pre filled upper line before installing(messy). Just pumped the shiz out of the front brake lever and bubbles went away and tension is now perfect.
Had to adjust clutch inside primary side.
Yes tank came off.
Overall I learned a ton! Very happy I did it myself but also glad I don't have to do it again anytime soon. And saved about 800-900$ in labor my dealer would have charged.
Any recommendations? and if anyone has instructions could they send them to mas3273@yahoo.com
Haven't bought them yet and looking for a place that sells the bars and maybe a plug n play set up
