Monkey Bagger Bars with Pics (Install)
Old Apr 24, 2013 | 09:56 AM
  #801
hammr_hed's Avatar
hammr_hed
Thanks for the info...will come in handy when I change out the controls down the road.
Old Apr 25, 2013 | 07:57 AM
  #802
TexasSG's Avatar
TexasSG
Unless you just love spending money on something other than beer, wiring extensions & SE throttles are not necessary for 10" & 12" bars. As a matter of fact, after rerouting the harness, I'd bet there was enough slack for 14's.
Old Apr 25, 2013 | 08:17 AM
  #803
bencimino's Avatar
bencimino
Cool, bars are here today, cables on Tuesday, I have new seals and fluids looks like next weekend I'm tearing into it.
Old Apr 25, 2013 | 08:24 AM
  #804
hammr_hed's Avatar
hammr_hed
I didn't use extensions on my setup, but I'm not so sure I'd be able to move from 12" to 14" bars with out them...
Old Apr 25, 2013 | 08:45 AM
  #805
BigGelvis's Avatar
BigGelvis
Sorry but I call BS on that one.
When I pulled wires on my 13" LA Chopper prime apes? I pulled the clutch side first. I cut the plug off and left 1" of wires on it to splice it back on if needed.
I then pulled the OEM harness thru the pars and I only have about 3" of wire length coming out of the bars. It was short enough that it was a PITA to splice and solder all the wires that close to the bars.
The throttle side, I decided to splice the wires before pulling them. And it was a good thing I did because that side was even shorter had I pulled just the OEM harness thru.
As far as the TBW goes? I firmly believe it was better to buy the CVO kit and NOT splice any wires on that one. That totally eliminates any possibility of a splice failing down the road as it is solid wire from the grip sensor to the plug.
To each his own but as much money as you are spending of installing bars and as much of a PITA as it is, I would rather spend the extra $$ and make sure it is done right the first time then to have to pullit apart and do it again later or be stranded with a short in the TBW harness.
Old Apr 25, 2013 | 09:17 AM
  #806
Ryan2959's Avatar
Ryan2959
I used +6 but could have gotten by with +4 on the clutch and brake with my 12's. Stock would not have worked.
Cowboy
Old Apr 25, 2013 | 01:49 PM
  #807
dlpuette's Avatar
dlpuette
I noticed that many tutorials have you remove the gas tank for bar swaps. Uhm... why? If you watch the LA Choppers video, the tank remains, covered, but in place. I also noticed that they remove the front passing lights bracket and simply rotate the fairing out of the way. Is this how all of you are doing it? Seems a hell of a lot easier than removing the radio!
Old Apr 25, 2013 | 02:22 PM
  #808
ramnj's Avatar
ramnj
Originally Posted by BigGelvis
...To each his own but as much money as you are spending of installing bars and as much of a PITA as it is, I would rather spend the extra $$ and make sure it is done right the first time then to have to pullit apart and do it again later or be stranded with a short in the TBW harness.
Couldn't of said it better.
Old Apr 25, 2013 | 02:23 PM
  #809
Dew Me's Avatar
Dew Me
I haven't seen any tutorials showing removal of gas tank. Nor have I heard of anyone doing so. I think I know why though: I think on an ABS bike if the bars go high enough to replace brake line, or if someone replaces brake line for looks, that the brake line runs from the bars through the tank/backbone, and under the seat. Which would require removal of tank. I think I haven't heard of it b/c all the ABS bikes seem to be doing 10's and 12's.
I think people are doing it both ways. I hadn't heard of the one pushing the fairing away when I did mine so I removed the stereo. I did not think removing the radio was difficult at all. On the contrary, I liked having everything out of the way while in the right position so I knew all lengths were right and all routings were correct.
Old Apr 25, 2013 | 02:25 PM
  #810
ramnj's Avatar
ramnj
There's no need to remove the gas tank.
On the inner fairing, I just rotated it out of the way, but make sure its secure so it doesn't fall.
It is very easy to do...just time consuming.
