Riders Backrest
The problem with non-adjustable backrest is that you get tired of being in the same position. With the adjustable you can move forward and back, which gives you more comfort on the road. It is amazing how much relief you can get from just moving the backrest up or back 1/2 inch.
If you put the system on yourself be very careful in mounting. You'll have to remove the seat (of course) and the deflector. The biggest issue, for my money, was making sure I put the adjustment toggle in the right spot so that the deflector would fit over it. A dealer charges about 1.5 clock hours for the job, though I think it only takes about 45 minutes on a good day. But then again, on a bad day it might take 8 hours to correct whatever you screw up if you mount it wrong.
