Kromewerks Sweepers +2
Old Dec 24, 2009 | 02:21 PM
patriotmc's Avatar
patriotmc
Default Kromewerks Sweepers +2
I am going to change the stock bars on my 07 Ultra. After reading all the posts on handlebars, I've decided on the Kromewerks Sweepers +2. Does anyone know the Drag Speciaties pn for the 300505's? DS has several bars and I'm not sure which one is the 505.
Also, I know I'll need a 3" longer clutch and new trottle/idle cables (not sure how much longer required). If you know the Drag Specialties pn's for those parts, I would appreciate your help.
Thanks and Merry Christmas to all of you!
Old Dec 24, 2009 | 02:24 PM
dawg's Avatar
dawg
0601-0837 is the Drag number for the 300505's
Old Dec 24, 2009 | 02:32 PM
dawg's Avatar
dawg
These are the OE numbers for the HD parts that you would use. The throttle/idle cables are now obsolete, but you should be able to cross reference them in the back of a Drag book by pn#
Clutch=38649-07
Throttle=38650-98
Idle=56730-03
The throttle and idle cables can still be found at dealers on a parts locator for like $21 each. The -07 clutch cable from HD is like $80 though and is a lot more expensive than the pre 07's and 08 and up for some reason.
Old Dec 24, 2009 | 04:07 PM
patriotmc's Avatar
patriotmc
Dawg, thanks. This will help a lot!
Old Dec 24, 2009 | 04:51 PM
DPete's Avatar
DPete
Is there a chance of changing bars without haveing to bleed the front brakes? I guess if you tried to without unhooking the brake line from the master cyl. it would be to difficult with all the wiring etc. I have a bar change coming also, just waiting on the clutch cable.
Old Dec 24, 2009 | 05:37 PM
dawg's Avatar
dawg
You don't have to bleed the brakes as you shouldn't have to remove the brake line. Just unhook the whole shabang and let it gently sit on a towel or something on top of the gas tank while you swap the bars.
Old Dec 24, 2009 | 05:54 PM
DPete's Avatar
DPete
That's what I was hoping but have never done a swap with all those dam wires inside the bars, guess I'll learn soon
patriotmc
Dec 16, 2009 08:38 PM
Taterdog
Apr 5, 2009 03:16 PM
patsac
May 6, 2008 10:59 AM
soos
Nov 26, 2007 09:46 PM
moondog99
Sep 27, 2007 01:04 PM
