Arc amp ground question
Old Jan 15, 2010 | 07:09 AM
2067's Avatar
2067
Default Arc amp ground question
Is there anything wrong or that I need to worry about with running the amp ground to the negative post on the battery ?
(pardon the pun......but can I get both positive and negative thoughts on it),
Thanks............
Old Jan 15, 2010 | 07:26 AM
timvan's Avatar
timvan
I wouldnt do it on a car but on the bike I couldnt find a better ground and its not a very long run
Old Jan 15, 2010 | 07:32 AM
1flhtk4me's Avatar
1flhtk4me
"The ground wire should be connected directly to the chassis of your vehicle",this is quoted from the owners manual.
Not sure why?
I removed the rivet that holds the throttle cables and strain relief on the frame,then tapped the hole for a screw.I secured the ground at this point.
Old Jan 15, 2010 | 07:55 AM
timvan's Avatar
timvan
Not sure why?
Hope you removed some of the powdercoating to get a solid ground.
The reason they state to connect to chassis is that you do not want a long (over 3') ground run, it will degrade the power. I think I used 4' to batt ground which is still acceptable, just not optimal, This has worked flawless for the past 10 months
Old Jan 15, 2010 | 08:16 AM
sortasuave's Avatar
sortasuave
From what I have heard, there have been some people that have reported noise when grounded to any part by the battery. I didn't go directly to the battery but rather the lug the battery was attached to just under the seat. I did this because it can be a real pain to attach several wires to the battery as you add other power toys to the bike. I've not had any problems with this setup.
Old Jan 15, 2010 | 08:19 AM
acchd's Avatar
acchd
I've always gone directly across the battery(+, -) on 2 different bikes I've had with no problems.
Old Jan 15, 2010 | 08:39 AM
1flhtk4me's Avatar
1flhtk4me
Was I suppose to do that?
Old Jan 15, 2010 | 08:43 AM
timvan's Avatar
timvan
I would, and add some dielectric grease to prevent corrosion. The powdercoating is not a cundoctor, and the screw doesnt have much real estate to transmit current
Old Jan 15, 2010 | 08:53 AM
1flhtk4me's Avatar
1flhtk4me
Just messing with you!
I did remove the powder coat.
Old Jan 15, 2010 | 09:03 AM
timvan's Avatar
timvan
Did you put the flux capasitor inline as well?
Dont forget to grease the muffler bearing and add a new powerband while your in there.
