Redline Shockproof Heavy WOW!
Old Jan 22, 2010 | 02:10 PM
  #31
jdallenemtp's Avatar
jdallenemtp
Good info here, i am running all hd stuff now that the warranty is out was considering a change
Old Jan 22, 2010 | 02:11 PM
  #32
strtarrow's Avatar
strtarrow
What about weight of the Redline? I can't find a recommendation in my service manual uless I am not looking in the right place and I see they offer 3 different weights.
Old Jan 22, 2010 | 02:23 PM
  #33
FLTRI17's Avatar
FLTRI17
Originally Posted by Northside
....I just wonder how it comes out when you drain it to change oil
It comes out a bit slow, just like you would expect 90wt to drain. No, not all the oil is replaced with a change due to its superior cling capability, which s considered a quality, especially in reference to tranny oil that you want lubed even with the first turn of the gears.
...and do particles stay stuck to it on the gears?.
Well no. Since the oil is constantly "rinsing" the gears from running through it and getting splashed or slung onto them, the particulates sink and are found at the bottom of the tranny, and is first to get drained.
Hope this helps,
Bob
PS - Since the tranny doesn't suck air into it like the engine, the gearbox and gears are kept much cleaner than engine oil, which is why with regular 90wt, you can see the oil looks like new, even after 10,000 miles.
Old Jan 22, 2010 | 02:26 PM
  #34
FLTRI17's Avatar
FLTRI17
Originally Posted by strtarrow
What about weight of the Redline? I can't find a recommendation in my service manual unless I am not looking in the right place and I see they offer 3 different weights.
Just buy and install Shockprook Heavy (pink) or V-twin Transmission oil (the same with different label) as members here will attest, is a no-brainer.
Lots of years using it without anything negative. Also makes for discerning difference between tranny leak and primary leak due to color differences.
Bob
Old Jan 22, 2010 | 02:47 PM
  #35
skydrifter's Avatar
skydrifter
Does it void the warranty??
Old Jan 22, 2010 | 02:50 PM
  #36
'05Train's Avatar
'05Train
No it doesn't.
Old Jan 22, 2010 | 02:54 PM
  #37
BCguy's Avatar
BCguy
Another plus for Shockproof in the tranny. I switched from Amsoil 75/90 last summer and will never go back. A noticable difference.
Old Jan 22, 2010 | 03:19 PM
  #38
Ronp42's Avatar
Ronp42
Account Retired
Bob
Good point! I had an indy tell me it's very easy to tell what's leaking by the color...Good info here guy's. I love these weekly oil threads...plus we must remember, theres new people joining the forum and some are new bike owner's.
Old Jan 22, 2010 | 03:31 PM
  #39
menmia's Avatar
menmia
Ron,
I am one of those newbies, also new to HD. I have ridden metric sport bikes for most of my life, so reading the comments on the oil are good for me since I am now on a touring bike. There is a difference on what you put in the engine when you are knee dragging compared to riding it on down the road, so I am learning left and right in here.
So far I have learned to use Amsoil, then I learned that Redline was better and possibly Dextron in the primary. All of this with less than 1,000 miles, of my riding, on the bike. The bike came with 27,000, so I still have a couple thousand before I have to "know" what I am going to put in there. Like Noz said earlier, it is confusing, but we're trying to keep up and I know we appreciate the information being shared.
Thanks,
Bruce.
Old Jan 22, 2010 | 03:35 PM
  #40
hog-doc's Avatar
hog-doc
Originally Posted by NoCoLoco
I'm sure that stuff works great in warmer temps but how well does it work when it's 40 degrees outside?
Well Ive tested it all the way down to 4 below 0 and it worked just fine!
