What ecm/fuel controller?
Old Jul 27, 2006 | 02:26 PM
jerseyjeff62's Avatar
jerseyjeff62
Default RE: What ecm/fuel controller?
if your not going to make a lot of changes and just pipes & filter the dfo/tfi are the inexpensive and eziest way to make it run richer
Old Jul 27, 2006 | 05:01 PM
bdgreen's Avatar
bdgreen
I've had the PCIII on mine with SE slip on's & SE high flow air filter for a week now and I really like the way the bike is running. The install was extremely easy. The download can be done from your PC by using a 9 volt battery with the harness that comes in the kit. No need for a lap top. Also includes USB cable and disk. Including download on PC, the installation took all of about 15 minutes. If you add more to your engine, you can go on line and download again to re-map. Easiest job I've done on the bike so far.
Old Jul 27, 2006 | 09:27 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
I'll throw in a vote for the V&H Fuel Pack. I installed one on my 06 Dyna Superglide. Only downside is that there was precious little room under the seat for the connector.
Old Jul 27, 2006 | 10:11 PM
Matt8643's Avatar
Matt8643
PCIII, you can get it preprogrammed with canned map from fuel moto usa on the web.
Old Jul 28, 2006 | 01:27 AM
Mood Swing's Avatar
Mood Swing
ORIGINAL: fimduc
DFO from Techlusion/Dobeck works great for me as well.......simple and inexpensive way to tune a EFI Harley. No need for dyno tuning a lightly modified V-twin for everyday street riding. There are many HD riders that kept their bikes in great tune over the decades without every going near a dyno machine.
Amen Brutha!
Same here.
Old Jul 31, 2006 | 01:37 PM
saidin43's Avatar
saidin43
I gotta put my vote in the PCIII, installed it, really easy too. Already had the map preloaded. Started the bike, was purring like a kitten. Fixed the popping and coughing. I may tweak leaning it out a bit until I get the popping and richening it a bit to maximize my fuel efficiency, but I'm loving the tuner.
Old Jul 31, 2006 | 02:15 PM
bdjhog's Avatar
bdjhog
What (if any) opinions do people have on this company's product?
www.total-fuel.com
Old Aug 24, 2007 | 08:17 PM
wendy58's Avatar
wendy58
Stage I
hooking up terminal velosity on 06 nite-rod and can,t find what they call the crankpostion sensor to tie into any one run into this,,,or is it needed tied into and installed o2 sensor please help
Old Aug 25, 2007 | 04:52 AM
dumoore's Avatar
dumoore
PCIII, V&H Duals, Supertrapp SE & and K&N air filter most from Fuelmoto. Jamie pre-programmed the map...starts right up and no decel issues.
younggeezer
Oct 30, 2008 07:28 PM
doug garrison
Jan 26, 2008 08:37 PM
jcd15
Aug 5, 2007 02:21 PM
imboden
Apr 8, 2007 08:01 PM
chesterbud
Nov 27, 2006 11:33 AM
