Smells like gas...
Old Feb 3, 2010 | 08:52 PM
paulhog's Avatar
paulhog
Default Smells like gas...
Distinct smell of gas at intersections and when I get off the bike I can smell gas on my riding pants at the inner right thigh area. There's no liquid leak, just fumes. Any thoughts? Thanks.
Old Feb 3, 2010 | 08:57 PM
BadPiggy's Avatar
BadPiggy
Bad intake seals?
Old Feb 3, 2010 | 09:06 PM
strtarrow's Avatar
strtarrow
Drop a couple tabs of Gas X in the tank and call it good. Available at Wally World or any pharmacy.
Old Feb 3, 2010 | 09:26 PM
JimTJr's Avatar
JimTJr
I would say there almost has to be a liquid leak of some kind. (Even if it's a drop or two every few minutes.) Look for stains down in that area of the bottom of the tank? Fuel line, does the fuel vent tube go near that area on your bike? I also smelt gas fumes on my FXST and it took me a little while to see the stains start showing up. It turned out to be the vacuum fuel shut off valve leaking. Just a drop here and there, which could be blowing back onto your leg.
Mine only leaked while the bike was running, (I guess due to the vacuum "Turn on"?) This may also be the case for yours....
And gotta love EBAY! I found one on there off a parts bike for 20.00 shipped! (Dealer wanted something close to 80 I think!)
Old Feb 4, 2010 | 08:05 PM
paulhog's Avatar
paulhog
Default I found my leak!
It's the fuel line supply and return fittings. Looks like the fittings are about $180.00 each!! I get the feeling it's the o-ring on each fitting. Does anyone have any experience with this problem? Thank you.
Old Feb 4, 2010 | 08:08 PM
2011 Road Glide Ultra's Avatar
Check with the dealer for service bulletins - it may be covered....
Old Feb 4, 2010 | 08:13 PM
JimTJr's Avatar
JimTJr
What do you mean by the fittings? The shut off goes straight into the bottom of the tank, right? Lines from there out to motor?
Exactly where is it leaking from?
Old Feb 4, 2010 | 08:15 PM
paulhog's Avatar
paulhog
Thanks, but I doubt it. This is a '99 Road King with 53000 miles that's well beyond warranty coverage.
Old Feb 4, 2010 | 08:17 PM
Stansuski's Avatar
Stansuski
What year is the bike?,I had issue with my 2005 Ultra ,it was fuel line from tank which was changed to a different type updated line.
Stan
Old Feb 4, 2010 | 08:26 PM
BadPiggy's Avatar
BadPiggy
He's leaking at the disconnect.
There's an o-ring inside there.
