FBW questions when replacing handlebars
Old Feb 15, 2010 | 07:05 AM
scuba1954's Avatar
scuba1954
Default FBW questions when replacing handlebars
I am replacing the handlebars, grips and levers on my 09 RKC with FBW throttle. I have read the service manual but have not found any thing that says there is any adustments on the throttle grips for the FBW when installing new grips. Anyone know if there are any adjustments needed or is as simple as it sounds and does not need any adjusting?
Old Feb 15, 2010 | 07:29 AM
nitechecker's Avatar
nitechecker
No adjustments. Just be careful with the connecter in the bar. I had a friend who screwed his up. I've done a few now with no problems at all.
Old Feb 15, 2010 | 07:35 AM
SixSixRider's Avatar
SixSixRider
No adjustments. I swapped grips on my wife's '09 Street Glide (to heated ones) and just swapped to Heritage bars on my Road Glide just this past Saturday. The throttle is easier than the ol' cable days. Good luck!!
Old Feb 15, 2010 | 07:55 AM
scuba1954's Avatar
scuba1954
Connector in the bar? Are you referring to the twist grip sensor inside the bar or being careful and using a cardboard spacer when removing brake levers?
Old Feb 15, 2010 | 08:03 AM
Jinks's Avatar
Jinks
There's a small connector about half way down the handlebar. You'll have to back feed some of the wiring in order to get it out the end of the bar & unplug it. Not complicated.
Old Feb 15, 2010 | 08:05 AM
keltonkrew's Avatar
keltonkrew
inside the bar is a green plug. you have to unplug that to change the bars out. the pin connectors inside that plug are small and could damage easily. not a big deal, just be aware of it and you'll be fine.
Old Feb 15, 2010 | 08:45 AM
nitechecker
Excatly.....No big deal at all
Old Feb 16, 2010 | 09:54 AM
scuba1954's Avatar
scuba1954
Yeah, I read my service manual gave a heads up about that hidden connector. It also shows a really good pic of what it looks like. Thanks for the warning, it's greatly appreciated.
Old Feb 16, 2010 | 06:07 PM
patsfan's Avatar
patsfan
One more tip:
When you're putting the throttle side grip back on, make sure its not too tight against your switch housing or you'll have a poor mans version of cruise control.
Don't ask me how I know.
ghostflamed
Feb 28, 2017 04:47 PM
don g
Oct 3, 2011 02:31 PM
RidemyEVO
Jul 2, 2010 09:04 PM
RocketRocker
Dec 15, 2009 11:42 AM
BLT
Oct 27, 2006 04:47 AM
